First ----- Second---- Nothing!
First ----- Second---- Nothing! was created by Airportable
Posted 6 years 4 months ago #186825
The short gear cable on the f has parted just when I should be taking full advantage of this brilliant weather: Bugger. It failed about a mile from home & by making the home run, it's now over the pit & I have the failed end in my hand; much the same picture as that from our man in Vancouver.
Obviously I've looked at the How To & absorbed those thoughts, however it is several years old, so there may be some new thinking on this & if not can I have you comments & if there are non, your commiseration.
Mike.
Replied by graham1 on topic First ----- Second---- Nothing!
Posted 6 years 4 months ago #186831
sounds like your having the same luck as me,,,,, none,:(
by graham1
Replied by David Aiketgate on topic First ----- Second---- Nothing!
Posted 6 years 4 months ago #186835
Unfortunately, this is still a pig of a job.:(
There hasn't been any miracle quick fixes found since the how to was written.:nonod:
Last Edit:6 years 4 months ago by David Aiketgate
Last edit: 6 years 4 months ago by David Aiketgate.
Posted 6 years 4 months ago #186836
hi,David, i wish you could tell me a quick fix for my clutch bleeding. :-?
by graham1
Replied by Airportable on topic First ----- Second---- Nothing!
Posted 6 years 4 months ago #186866
Lead awake last night praying for rain & inspiration, when it occurred to me to remove the broken inner, order the whole cable & try & refit the new inner before committing myself to the full renaissance bit & see how that goes. So early up & centre console out before Church & slackened the now popped off ball joint & remove. Then Church stuff & Bar-b-cue at my sons. Home & under the car; remove gearbox end & try to push cable back from in the cockpit end; no go; then try to draw it forward out through the car & it's out & on the bench, granted I had to cut it but hey ho, its not being used again. I'll post the next bit later in the week, or when ever the parts arrive.
Mike
Posted 6 years 4 months ago #186876
Well it can't be done like that, one ends must be crimped on when the inner core is through the outer; I should have realised the inner bore wouldn't take the 6mm end slug. Parts ordered & we're in for the long haul.
Posted 6 years 4 months ago #186878
looks like you have it all sorted out now, just hope it works out ok, :broon:
by graham1
Posted 6 years 4 months ago #186923
And so a big job has broken out! Some of the bulkhead captive nuts are stripped & two of the hex securing screws have rusted into cylinders, plus I'm well past the stage when bending double in the pit didn't required serious consideration, so, I think I'll start the winter jobs now & take the engine out then I can stand up & do the job properly.
I was considering selling the TF a couple of months ago, thank goodness I didn't as there's a lot more summer to go at yet.
Posted 6 years 4 months ago #186940
:omg:
Time to create page: 0.512 seconds
