MG F exhaust 'putt putt putt putt" sound
MG F exhaust 'putt putt putt putt" sound was created by gooseholla
Posted 6 years 3 months ago #187378
Hello all,
My MG F Trophy has a janspeed back box on. To me it doesn't sound right. When sitting at idle every so often it has a kind of low down 'putt putt putt putt' sound. I can't seem to capture on camera as my microphone is overpowered by wind noise and engine noise. It likes to shake a bit then might settle down, then will do it again, and repeat. Revs stay the same around 850ish mark.
I took it to my local garage I've used for years. They listened and didn't think there was anything wrong with it. But you know how you are used to a car and just 'know' when something seems wrong?
Is it my paranoia, or a rough idle, or more severe problem - misfire maybe?
Regards
John
Replied by gooseholla on topic MG F exhaust 'putt putt putt putt" sound
Posted 6 years 3 months ago #187380
I have recorded a video. It isn't very clear through a phone's speaker, but when I have headphones on I can hear it. Hopefully it helps! It is most obvious to me from about 1:20 onwards.
Regards
John L
Last Edit:6 years 3 months ago by gooseholla
Last edit: 6 years 3 months ago by Leigh Ping. Reason: Double posted video removed.
Replied by David Aiketgate on topic MG F exhaust 'putt putt putt putt" sound
Posted 6 years 3 months ago #187383
paranoia...
Replied by talkingcars on topic MG F exhaust 'putt putt putt putt" sound
Posted 6 years 3 months ago #187388
I didn't notice anything.
Posted 6 years 3 months ago #187390
It is hard to hear I know, and I will try and get a better recording because it is so obvious in person but not so great on the recordings I try and do.
Replied by jelly on topic MG F exhaust 'putt putt putt putt" sound
Posted 6 years 3 months ago #187391
Was I the only one who "thinks" the exhaust is blowing?
by jelly
Posted 6 years 3 months ago #187392
There is definitely something up with it. It makes strange noises and the fumes don't come out smoothly, it kind of fires out in bursts.
Replied by Leigh Ping on topic MG F exhaust 'putt putt putt putt" sound
Posted 6 years 3 months ago #187394
gooseholla wrote: There is definitely something up with it. It makes strange noises and the fumes don't come out smoothly, it kind of fires out in bursts.
Don't forget that over time carbon build up may change the sound of an exhaust's original note. Without other symptoms being evident, it's likely that you're overthinking it. It sounds nice and meaty to me. :broon:
Posted 6 years 3 months ago #187407
There are a few things that might indicate it isn't just paranoia!
1.Coolant loss started with no external signs. Tried three different caps.
2. not so long ago (miles wise) previous owner had complained of poor running and garage said just keep an eye on it.
3. Not so long ago a code for a misfire on cylinder 4
I changed spark plugs and waiting for a fuel filter to change. Air filter was cleaned out. But when I first had the car after a while the IACV would need resetting as it would frequently get stuck at 1000- 1100, so I'm wondering if it is something to do with that, or if a cylinder is starting to misfire.
It is hard to explain. When you start the car up it starts about 1050 - 1100 revs and slowly drops, as I would expect. Idling at these revs the noise isn't present. As it drops to about 850 RPM that is when it starts. You get the normal noise exhaust noise then all of a sudden three or four boom booms or putt putt noises in a row where it shakes a bit. Longer you idle the more frequently the boom booms happen.
John
Last edit: 6 years 3 months ago by gooseholla.
Replied by davidgv1 on topic MG F exhaust 'putt putt putt putt" sound
Posted 6 years 3 months ago #187409
Hi G
Check out the inlet manifold. You probably have the plastic manifold which do warp and can lead to water loss, ie, internally and externally.
If it is leaking into a cylinder, then this could cause the problems that you have.
The following user(s) said Thank You: Leigh Ping, sworkscooper
Posted 6 years 3 months ago #187410
I have the trophy 160 so it has metal intake. Do these leak as well?
Posted 6 years 3 months ago #187411
Also on a side note why is this dirt or particles suddenly appearing in my expansion bottle?
Cheers for help so far people
Time to create page: 0.554 seconds
