MG F exhaust 'putt putt putt putt" sound
Replied by talkingcars on topic MG F exhaust 'putt putt putt putt" sound
Posted 6 years 3 months ago #187413
Get your head gasket checked.
by talkingcars
The following user(s) said Thank You: davidgv1
Replied by Steve on topic Re:MG F exhaust 'putt putt putt putt" sound
Posted 6 years 3 months ago #187418
I would get a sniff test done, I would suggest that the chuffing is steam build up and the black bits are carbon.
A call to Jon Norris of Rough luck racing will confirm or allay your fears, he's a good guy and very knowledgeable reasonable prices for repairs too.
Sent from my MediaPad T1 8.0 Pro using Tapatalk
Last Edit:6 years 3 months ago
by Steve
Last edit: 6 years 3 months ago by Steve.
- gooseholla
Replied by gooseholla on topic Re:MG F exhaust 'putt putt putt putt" sound
Posted 6 years 3 months ago #187423
Today I replaced spark plugs and fuel filter to see if it was something to do with those. Still the same. I decided to get under the car, I thought if coolant not visible up above, then maybe down below.
This is below the engine at the gearbox, so cylinder 1? Does this indicate a leaking head gasket. Pinkish run down and the UV light highlighted it green - I had put some UV dye in the system to help try and find the leak. Looks mighty wet!
by gooseholla
Replied by talkingcars on topic Re:MG F exhaust 'putt putt putt putt" sound
Posted 6 years 3 months ago #187426
by talkingcars
- gooseholla
Posted 6 years 3 months ago #187435
I'm going to attempt to change the inlet manifold gasket as 1. There seems to be evdience of wetness on the side of the manifold by cylinder 4 and also it can run round to that point on the head. 2. It is a nice bit of experience to bleed and refill the coolant system. 3. If it is the head gone anyway can't do any real damage in trying the IMG!
I also noted that the coolant pipes in the engine bay, those nasty mild steel ones are flaking and rusty, so probably time to change those over the winter too!
by gooseholla
Time to create page: 0.511 seconds
