MG F exhaust 'putt putt putt putt" sound
- gooseholla
MG F exhaust 'putt putt putt putt" sound was created by gooseholla
Posted 6 years 3 months ago #187378My MG F Trophy has a janspeed back box on. To me it doesn't sound right. When sitting at idle every so often it has a kind of low down 'putt putt putt putt' sound. I can't seem to capture on camera as my microphone is overpowered by wind noise and engine noise. It likes to shake a bit then might settle down, then will do it again, and repeat. Revs stay the same around 850ish mark.
I took it to my local garage I've used for years. They listened and didn't think there was anything wrong with it. But you know how you are used to a car and just 'know' when something seems wrong?
Is it my paranoia, or a rough idle, or more severe problem - misfire maybe?
Regards
John
- gooseholla
Replied by gooseholla on topic MG F exhaust 'putt putt putt putt" sound
Posted 6 years 3 months ago #187380Regards
John L
Replied by David Aiketgate on topic MG F exhaust 'putt putt putt putt" sound
Posted 6 years 3 months ago #187383David
Replied by talkingcars on topic MG F exhaust 'putt putt putt putt" sound
Posted 6 years 3 months ago #187388
- gooseholla
Posted 6 years 3 months ago #187390Please Log in or Create an account to join the conversation.
Replied by jelly on topic MG F exhaust 'putt putt putt putt" sound
Posted 6 years 3 months ago #187391Please Log in or Create an account to join the conversation.
- gooseholla
Posted 6 years 3 months ago #187392Please Log in or Create an account to join the conversation.
- Leigh Ping
Replied by Leigh Ping on topic MG F exhaust 'putt putt putt putt" sound
Posted 6 years 3 months ago #187394gooseholla wrote: There is definitely something up with it. It makes strange noises and the fumes don't come out smoothly, it kind of fires out in bursts.
Don't forget that over time carbon build up may change the sound of an exhaust's original note. Without other symptoms being evident, it's likely that you're overthinking it. It sounds nice and meaty to me. :broon:
- gooseholla
There are a few things that might indicate it isn't just paranoia!
1.Coolant loss started with no external signs. Tried three different caps.
2. not so long ago (miles wise) previous owner had complained of poor running and garage said just keep an eye on it.
3. Not so long ago a code for a misfire on cylinder 4
I changed spark plugs and waiting for a fuel filter to change. Air filter was cleaned out. But when I first had the car after a while the IACV would need resetting as it would frequently get stuck at 1000- 1100, so I'm wondering if it is something to do with that, or if a cylinder is starting to misfire.
It is hard to explain. When you start the car up it starts about 1050 - 1100 revs and slowly drops, as I would expect. Idling at these revs the noise isn't present. As it drops to about 850 RPM that is when it starts. You get the normal noise exhaust noise then all of a sudden three or four boom booms or putt putt noises in a row where it shakes a bit. Longer you idle the more frequently the boom booms happen.
John
Replied by davidgv1 on topic MG F exhaust 'putt putt putt putt" sound
Posted 6 years 3 months ago #187409Check out the inlet manifold. You probably have the plastic manifold which do warp and can lead to water loss, ie, internally and externally.
If it is leaking into a cylinder, then this could cause the problems that you have.
- gooseholla
Posted 6 years 3 months ago #187410Please Log in or Create an account to join the conversation.
- gooseholla
Posted 6 years 3 months ago #187411Cheers for help so far people
