Mike Satur's coilover conversion install - any experience?
Mike Satur's coilover conversion install - any experience? was created by mowog73
Posted 5 years 8 months ago #188351[size=10pt]Mark[/size]
95 MGF
Replied by Denmark on topic Mike Satur's coilover conversion install - any experience?
Posted 5 years 8 months ago #188352I have installed the kit om my ‘96 Mgf. My kit was the mk 1 kit where the turrets was a different design. Those turrets was a bit tricky to install, but the later design turrets are easy to fit. The rest of the kit is straight forward, but it takes some time.
After the conversion the car is handling and driving perfect. Suddenly the car has a suspension :clap:
The only adjustment i had to do after the install was a front wheel allingment.
Replied by mowog73 on topic Mike Satur's coilover conversion install - any experience?
Posted 5 years 7 months ago #188355From reading the instructions provided, the assembly of the new suspension arm and fulcrum seems difficult but I take it that is is simpler than it seems. I imagine it will become clear once I start the install.
95 MGF
Posted 5 years 7 months ago #188358Yes when you start i will be clear. To get to the front suspension arms you have to remove the front bumper and crash can. It is not difficult but it all takes time.
Also removing the hydragas spheres is straight forward, but again the space is limited and therefore you have to puzzle a bit.
I did my conversion on 2 x 6 hours and had no issues as snappes bolts or so.
I have set the car at the lover limit in the standard ride height range and the suspension adjusted as mentioned in the instruktions from Mike Satur.
At the first drive i at once noticed, that the suspension was firm but comfy. The handling was a little “stiff” and the directionally stability was not good. I could see, that there was a toe out on the front wheels. After a wheel alignment the car is driving absolutely perfect. (Only the front wheels was adjusted)
I had to correct the ride height a little after some driving.
I am sure you will be pleased whit the conversion..
My only concern is how it will go when MOT time comes next autum, but then again in Denmark the MOT men dont know how a MGF is built as it here in Denmark is a very rare car.:dry:
- campbosshassi
Replied by campbosshassi on topic Mike Satur's coilover conversion install - any experience?
Posted 5 years 7 months ago #188364I am going to check if I can fit and then get some sort of compliance check.
Failing that how long would it take a pro to remove and refit each MOT a bit drastic I know.
Replied by Cobber on topic Mike Satur's coilover conversion install - any experience?
Posted 5 years 7 months ago #188373Here in Oz the authorities don't know anything about them, and there were probably more sold here than in spain.
And if you feel the Gaz shocks are too much of a give-away.........paint the bastards black before you fit them.
Posted 5 years 7 months ago #188374Swapping out original suspension for aftermarket is big business here, especially on 60's and 70's muscle cars.
95 MGF
- SundanceUK
Replied by SundanceUK on topic Mike Satur's coilover conversion install - any experience?
Posted 5 years 7 months ago #188376Can't remember which ones, but it must have been around April/May time..
Sundance
- campbosshassi
Posted 5 years 7 months ago #188384Please Log in or Create an account to join the conversation.
- campbosshassi
Posted 5 years 7 months ago #188385Please Log in or Create an account to join the conversation.
