Seized rear callipers
- mgtfbluestreak
mgtfbluestreak wrote: He already mentioned using 6 point sockets...then again if they are cheapo worn ones then they have damaged the head from the start. ..so mangling bolts that are stubborn are the last of your worries...chuck the bolts and get some new...we talking about brakes not window wipers..it also depends on who fitted those brakes...I've seen people use cheap sockets made of monkey metal round a bolt as they fit it...and the next to realize that is the poor person removing it ..loctite muppets are everywhere...seen new Apr entices tighten bolts with there worn sockets and wrong grade loctite and wrong torque..and my irwin sockets removed the wrong doing where no other type will even sniff it .if you want heat on those bolts fly the tf to Cobber I bet it's hot over is side of the world
Nah it's winter here in Oz
Currently here in Melbourne at 23:10 hours it's 11degC
- mgtfbluestreak
Thanks for the support.
So turned to the passenger side. Did the same cleaned and filed the pad edges, cleaned the locating clips etc. All fine. Tried the piston and yes it moves out but no way is it going to wind back. Quick look under the seal and it's the rusty rim job. I've taken the caliper off with a view to cleaning up the piston (hopefully!) and renewing the seals.
Question folks. Are the seals limited to the TF or, being lucas used on other cars? I want to give my local motor factors plenty of help to find the right thing.
Cheers.
:yesnod:
