Losing coolant
- a Guest
- Visitor
I had this car for about three months, never had a problem and it drove like a brand new car, when all of a sudden a huge burst of steam comes from the engine clouding the car behind me (hehe) and forcing me to pull over. I usually wait for it to cool, slowly unscrew the cap from the coolant tank and wait a little longer, first time this happened, I had been driving from Barnstaple to Bristol, the drive down there was fine, no problems, even at high speeds, the drive back was fine all the way home until getting to my junction when it all of a sudden happened. Pulled over and filled up a little bit more water, didn't put the cap on the coolant tank and slowly drove to the garage a little down the road to wait for my dad to come out and to also get some free water.
Any way, after I had filled up, I drove home from the garage fine, (about 8 miles) and it drove for a while after fine, no problems, I did take it to a garage and they just filled her up with radweld and also said one of the pipes from the system was quite loose so they had fixed that up.. £136 later I leave the garage, drive home perfect, as it had been since the 'incident'.
About a month or two later, the same thing happened again, took it back to the garage, they said no signs of head gasket failure and filled her up with yet more radweld.. this lasted about 2 or 3 weeks when it happened again, at this point I was fed up and began driving the Corsa around again.. a few weeks ago however, my dad was driving the TF to work, was sat in traffic and it happened again, the car has been there ever since (until we towed it home today) and I'm set on figuring out what is going on with it.
I'm going to check for leaks, and any signs of the head gasket going again tomorrow just incase something has developed since it was last properly checked.
Any other ideas would be a great help! I don't have the funds to put anything serious right at the moment but even knowing the fault would put my mind at risk :yesnod:
Sorry for the essay! :bye:
they have a habit of failing which may explain the steam from the engine compartment :dunno:
one of the clever people will be along shortly to offer their advice :whistle:
- a Guest
- Visitor
phil-hex;9687 wrote: a first port of call ................ have you tried a new coolant bottle cap?
That might be an idea to try tomorrow, I will pop down the scrappy and see if there are any lying about, thanks for the idea Phil :idea:
- gotenks1321
Tomm;9688 wrote: That might be an idea to try tomorrow, I will pop down the scrappy and see if there are any lying about, thanks for the idea Phil :idea:
I'd get a new one instead of one from a scrappy, they could be just as bad.
I'd also be worried about the two lots of Radweld put in by the garage, it's not good for the K series at all.
MG TF LE500 27 of 500
- a Guest
- Visitor
gotenks1321;9689 wrote: I'd get a new one instead of one from a scrappy, they could be just as bad.
Yeah, will have to see what father says as he is 'funding' this latest fault :frown: thanks for the advice
- a Guest
- Visitor
MGFmad;9690 wrote: I would go for the cap first as well, if no luck with this, get your engine hot and then check all rubber coolant hoses, squeezing them to check if you have any small cuts/splits - I had one that would only open up after a long run!
Yeah the cap seems the way to go at the moment, the thought of the cap being the problem had never even crossed my mind :shake:. I'll try and take it out for a drive tomorrow and have a go at pipe squeezing too
The problem with coolant loss is that there are so many places it can be leaking.
Check:-
The underfloor pipes to the radiator.
The radiator and the bleed screw.
The pipes that run to and from the heater matrix - inside the tunnel console.
The heater valve.
The pipes in the engine bay.
That should keep you busy for awhile.:whistle:
Oh, and you will probably have to bleed the coolant system to ensure there is no air in the system.
You are refilling with coolant not just water, aren't you?
Try to see a rough area where the steam is coming from. Have a look to see if you have any staining from the leaking coolant.
As said, it could be anything from the head gasket to a 50p clip holding a hose on.
Change the expansion tank cap first and go from there. It is fairly cheap so worth changing anyway.
- a Guest
- Visitor
I'm pretty sure it might be the cap, I think that's where the steam leaks from when it 'explodes'.
Tomm;9692 wrote: Yeah, will have to see what father says as he is 'funding' this latest fault :frown: thanks for the advice
i believe they are only about a fiver
- bryan young
