TF lower suspension bolts
I’ve recently changed my suspension to the soft ride shocks using new bolts. I had doubts about the accuracy of my torque wrench that I used on the lower bolts so a few days later I tested it with weights and it was clicking at 75nm instead of 100nm.
So I bought some of rimmer bros updated bolts and a new digital torque wrench and changed the four bolts.
I was on the Mike Satur site the other day and he’s released his version of these bolts saying that the rimmer updated bolts are not the way to go. Basically he’s saying they will still snap. I don’t like the look of his version I must say.
So now I’m bricking it, I’ve not even tested the car yet, too scared something is going to snap.
Help me put my mind to rest please, I should’ve left everything alone.
Pete.
Mike
That makes sense, may try those at my next rebuild. Certainly nothing to worry about. Did Mike elaborate why they are not suitable ?
Mike
https://rimmerbros.com/Item--i-RYG000400UR
these are the mike satur ones
https://www.mikesatur.co.uk/-MGTF-Lower-Shock-Bolt
Since the bolts are subject to shear forces, the thicker the shank the less chance of a break, I think I would go with the Rimmer bolts in this case.
These innocuous looking bolts have a big job to do!It is recommended that the lower bolt is always replaced after use. It must be torqued to the correct figure making sure the threads are cleaned before fitting the bolt using the correct tap so the bolt can be screwed in by hand.What Mike Satur has said,
There are two types, the standard MG one or a higher tensile cap head bolt.
Because these have a habit of snapping I recommend they are changed for the socket cap head ones.
The main issues with these bolts snapping is, the threads are not cleaned (use a M12 tap and wash out any debris) so the bolts can be screwed in by hand (NOT a hammer/impact wrench) then correctly torqued to 110N/m. The alignment of the bolt/thread /bearing rebate in the arm are out of alignment.These must be checked before hand for alignment. DO NOT use a hammer to assemble as I have seen reported by one Guy on a MG forum.That is one way of modifying your MG but not the correct way!!
Check the old bolts when removed, if they have witness marks on them and bent this could be a sign that you need to investigate further as the bolt could be binding on the inner bearing surface and the alignment of the mating part is out. This will require another arm fitting.( I have seen the rebate in the arm out of concentricity with the threaded section by 1mm so the bolt will bind and snap eventually!)The bolt can 'relax' as the correct torque is not reached causing the characteristic failure.
In my opinion the failure of the stock bolt is not because there is a large tolerance fit between the bolt and bore of the bearing but because of the parts not being in alignment/the bolt stretches beyond design limits causing it to relax. Using a tighter fitting bolt is not a way I would recommend as it reduces the tolerances between the bearing/arm rebate and the threaded part of the arm and the internal finish of the bottom bearing is not a true machined fit,fitting a tighter stronger bolt is a recipe for future problems! Imagine removing a high strength bolt that had to be forced into place and is now immovable ..yes it's going to snap off in the arm!!
The standard factory one is no longer stocked.
Is the hub itself threaded, have i missed something obvious like that or am just not hitting it hard enough ?
As soon as the new wishbone is in i need to move the car round to work on drilling and extracting the subframe rear mounting bolts on the opposite side that sheared rather than undid the other day when trying to lower the subframe. Its odd as everyone seems to say there are 3 bolts each site but i count 4 on the TF, one of them also holds the X cross brace.
Mark the bolt centre with a small centre punch, then when your happy it as close as you could get use a big punch & make sure it knows it’s been hit. Centre drill with a dumpy drill, a new WS 4 or better still a 5 is a good investment & Keep going until there’s no chance of the main drill wandering. Don’t use a battery drill unless it’s a real professional bugger, a corded drill won’t go flat, if it goes up in smoke that’s indicative of you need a better drill when you replace it. Use tungsten carbide drills made in the north of the northern hemisphere, although the last Dormer drills I bought were made in Brazil, the same with taps which you’ll need to retap the thread. Don’t break a drill, their really hard, even grotty ones.I broke a tap in part of a locomotive I was building & had to take the frames to another town to have the broken bit spark eroded, you can’t do that if you brake a drill in a mounting point. And there’s always tomorrow.
To do this I use a pneumatic die grinder with a ball end carbide burr to carefully grind the bolt end smooth with a slight bowl depression ….. be careful and get a good grip, these things spin up over 30,000 rpm, and wear eye protection
Now you can get your punch dead centre
To dill out the bolt I use left handed cobalt drill bits start with a 3mm pilot hole and work your way up in stages to the size you would use to tap a thread into that size hole, I use a pneumatic drill spinning pretty slow.
By using left hand drill bits running slow. The drill bit will bite and when it does it may unwind the bolt outta the hole for you.
If it doesn’t you can keep going up a size until you get to the size the you would use to tap a thread for that size bolt. If then it hasn’t unwound the bolt you can pick out some of the remaining bits of thread from the bolt hole and run the thread tap through
This only works if you started your pilot hole dead centre…. You did centre punch your hole dead centre didn’t you! If you fail to punch it in the centre use the die grinder to smooth away your punch mark and punch it again in the bloody centre this time!
Use a good cutting lubricant whist drilling and tapping
I use Treflex HD cutting fluid
