Hard Top question.
Hard Top question. was created by ips1
Posted 3 years 2 weeks ago #197506
Does the hard top from a MGF fit the TF?
Thanks in advance.
Last Edit:3 years 2 weeks ago by ips1
Last edit: 3 years 2 weeks ago by ips1.
Replied by bryan young on topic Hard Top question.
Posted 3 years 2 weeks ago #197507
YES, all of the hardtops are interchangeable ''one size fits all'' - If the hardtop is from a very early 'F' the rear catches may need changing as the early ones were not adjustable.
You will also need a switch, relay & possibly a 25amp fuse to make the HRW work, the wiring is there already - unless you already have a glass window in your soft top .
Ensure the top has the short wiring loom on the rear window, these are available if its missing !!
Last Edit:3 years 2 weeks ago by bryan young
Last edit: 3 years 2 weeks ago by bryan young.
Replied by ips1 on topic Hard Top question.
Posted 3 years 2 weeks ago #197508
Thank you Bryan.
by ips1
Replied by David Aiketgate on topic Hard Top question.
Posted 3 years 2 weeks ago #197512
Just a word of caution, most hard tops spend their life not on the car, lol. :whistle:
Posted 3 years 2 weeks ago #197513
LOL.
by ips1
Posted 3 years 2 weeks ago #197519
Mine hasn't been on the car for Four years, its only been on once when I first got it, Its nice to have a heated rear window .
Posted 3 years 2 weeks ago #197522
I am not right keen on them, but when done my TF will be my main transport all seasons. So need to consider the option.
by ips1
Replied by Goodwood on topic Hard Top question.
Posted 3 years 6 days ago #197635
Try to avoid the very early MGFs hardtops. Plan on having to recover the hardtop liner if it has not been done already. They all sag unless it is a Heritage hardtop with leather. Not a big deal. Also, watch out for the condition of the seals. These are NLA and not easy to source used. Not everyone is a fan, but I find them to be nice to have in the cold weather. Transforms the car into a coupe.
Replied by deepfat on topic Hard Top question.
Posted 3 years 6 days ago #197644
My first winter as an owner and I'm going to be putting my hard top on soon as I'm a sissy but one thing concerns me will the hood go mouldy? I will try to make sure it's as dry as poss before the top goes on but!
What do others do, do you take the top off occasionally to air the hood if so how often, can I treat the hood with anything before I put the top on?
by deepfat
Posted 3 years 4 days ago #197675
Make sure the hood is dry before folding down, zip out the rear window and lay this flat on the parcel shelf ( I used a thin towel to protect this) Fish out the heated rear window cable before folding .
Posted 3 years 3 days ago #197692
I have fitted a heated glass window so does this apply still apply or should I leave it in
by deepfat
Posted 3 years 3 days ago #197694
Hi, the glass rear window should sit flat on the parcel shelf anyway with the hood folded down. the reason why the plastic window should be zipped out as it folds and could split if left like this for months !!!!
Time to create page: 0.599 seconds
