Battery cut off
Battery cut off was created by deepfat
Posted 2 years 5 months ago #199251
I wanted to fit a battery cut off and went for the post mounted one for easy fitment but it only fits the (smaller0 negative post and not the (larger) positive post does anyone know of one that fits the positive post?
Failing this are the remotely mounted cut off switches capable of handling the starter loads? all the ones I saw are rated at 100 amps continuous with very short times (sec's) of up to loads of 500 amps, is this adequate?
by deepfat
Replied by Roverlike on topic Battery cut off
Posted 2 years 5 months ago #199252
Any link to cut off switch as I am intrugued where it is mounted when you say you have smaller negative post and bigger positive post?
If it is battery terminals both battery terminals (positive and negative) are the same size in my case.
Last Edit:2 years 5 months ago by Roverlike
Last edit: 2 years 5 months ago by Roverlike.
Replied by deepfat on topic Battery cut off
Posted 2 years 5 months ago #199255
It seems to be standard that the positive is larger (19mm) than the negative (17mm) probably to stop people fitting the battery incorrectly, I admit that I always thought they were the same size before this. I can open out the clamp to fit the isolator on the positive post but then the 19mm on the existing lead wont fit on the isolator 17mm secondary post. I could pack it out but would prefer something that fits tightly and neat.
by deepfat
Replied by SteveFMk1 on topic Battery cut off
Posted 2 years 5 months ago #199256
I have an isolator fitted to the earth post and it works a treat. One complete revolution on the knob to complete the circuit, synchronise the fob, and away you go.
Posted 2 years 5 months ago #199258
Yes I fitted it to the earth as I was there but I want it on the live so I can put a jumper to the radio then I wont have to tune the thing in every time I disconnect the battery.
by deepfat
Replied by julianfoulger on topic Battery cut off
Posted 2 years 5 months ago #199260
It fits the negative because it is the negative (earth) that one should be disconnected first, not the positive, for safety reasons.
Posted 2 years 5 months ago #199262
I understand that for safety you should disconnect the earth first as this means when undoing the live if you accidently touch the body or another earthing point you wont complete a circuit. When a device like an isolator is fitted and no tools are involved I can't really see what difference it makes as long as the circuit is broken.
For those of us old enough to know most cars used to be positive earth, from what I've read this was changed because alternators replaced dynamos and that required the change, but the rule in my book is always disconnect the earth first regardless of polarity.
by deepfat
Posted 2 years 5 months ago #199275
David I will have a look but I suspect this too is made for the negative terminal, the clue I spotted was the N stamped on it
by deepfat
  • Away
Replied by Cobber on topic Battery cut off
Posted 2 years 5 months ago #199276
If you wanna [solate from the + side then you need to use remote battery isolator switch like these:
You can even get n electronic version with remote control:
But I'd be wary of this one.....dubious Chinese quality , there may well be some out there made in places where moe care is taken when things are made
Posted 2 years 5 months ago #199278
I think your right I can't find an isolator to fit the positive post anywhere, it's a bit more work but what else would I be doing, going to the pub, sitting in the sun, driving to the coast
by deepfat
Time to create page: 2.366 seconds
