Battery cut off
yep, sorry for the confusion, I was replying to roverlike's query about what it is...David I will have a look but I suspect this too is made for the negative terminal, the clue I spotted was the N stamped on it
And my solution to the radio problem would be to run a separate earth to it so that it retains its memory when the battery negative is isolated.
Last Edit:2 years 5 months ago
by David Aiketgate
Last edit: 2 years 5 months ago by David Aiketgate.
Always disconnect the earth first, no matter if it is a negative earth car or a positive earth car. This is the safe way to isolate the battery. The battery cut-off should be on the earth lead of the battery.
[size=10pt]Mark[/size]
95 MGF
by mowog73
Time to create page: 0.549 seconds
