Temperature gauge fluctuating
Temperature gauge fluctuating was created by Dalo2906
Posted 2 years 2 months ago #199953
Hi all
Has anyone ideas of cause for fluctuating coolant temp gauge please?
Car is 1997 MGF 1.8 VVC
Temp comes up to normal while driving, then drops two graduations on the gauge. It slowly recovers to normal then repeats the performance continuously for the rest of the trip. Town driving, nothing too hectic, moderate ambient air temp. Cooling quite important with Aussie summer not far away.
Would appreciate possible causes please.
Thank you
Replied by SteveFMk1 on topic Temperature gauge fluctuating
Posted 2 years 2 months ago #199959
Might be worth checking the thermostat.
Replied by Airportable on topic Temperature gauge fluctuating
Posted 2 years 2 months ago #199962
There’s bugger all current flowing in these circuits so any high resistance on contacts or earth returns can cause many a headache. This evening I managed to resolve an electrical problem which had evading detection for a couple of weeks; I’d failed to adequately cleaned the paint off a hole redesignated as a convenient earth. A couple of scrapes with my penknife & alls well.
Look for simple problems first, even with our cars the easy jobs still outnumber the difficult ones.
Replied by Dalo2906 on topic Temperature gauge fluctuating
Posted 2 years 2 months ago #199963
Thank you for those ideas. I’ll be installing a new thermostat in a couple of weeks (hip replacement), and I’ll check the circuit continuity. I’ll let you know what I find.
Cheers, D
Replied by David Aiketgate on topic Temperature gauge fluctuating
Posted 2 years 2 months ago #199966
Any quick deviation of the gauge is most probably electrical rather than temperature related.
The following user(s) said Thank You: Dalo2906
Replied by minimax on topic Temperature gauge fluctuating
Posted 2 years 2 months ago #199975
This appears to be cyclic and fairly predictable in its behaviour, so I reckon it is a failing thermostat, opening ok but not closing quickly enough, rather than rebellious electrons. As such, it needs looking at because if it jams in the closed position there will be trouble.
by minimax
Replied by julianfoulger on topic Temperature gauge fluctuating
Posted 2 years 2 months ago #199979
Firstly the temp gauge is dampened and secondly if the thermostat is intermittently failing it will go up from normal upwards and fall but never fall below the midway point (as long as the engine is running). I would put my money on the problem being electrical.
Posted 2 years 2 months ago #199980
No. If it opens and does not close fully then the engine temperature will fall. Consider what would happen if the thermostat is removed.
This is almost certainly a lazy thermostat. Electrical problems of this type are characterised by being intermittent. This is cyclic and predictable, like the operation of a thermostat.
Last Edit:2 years 2 months ago by minimax
Last edit: 2 years 2 months ago by minimax.
