Rear window stop adjustment - does not make contact
Rear window stop adjustment - does not make contact was created by Goodwood
Posted 2 years 2 months ago #200248I generally do not have a problem with window fit / alignment. My only issue is that the window stop (F) is not making contact (or just barely) with the rear glass rail stop (G/H). I cannot figure out how to make them come closer to each other. I tried adjusting 'B' but that did not seem to help (tightening made it worse)
In order to prevent the rear glass waist rail from getting caught above the window stop, I have placed the window stop at the highest position.
The fit of the window is generally good, it is just that the rear of the window goes a bit high when it is all the way up. It also stops awkwardly without the rear stop.
I have no issues with the front stop.
Any advice on how this can be adjusted?
Replied by Goodwood on topic Rear window stop adjustment - does not make contact
Posted 2 years 2 months ago #200249Please Log in or Create an account to join the conversation.
Replied by David Aiketgate on topic Rear window stop adjustment - does not make contact
Posted 2 years 2 months ago #200254David
Posted 2 years 2 months ago #200256Thanks for your reply. This window stop is relatively new. I purchased it from MGMania last year as a spare when I was adjusting the window (based on what I had read here, I assumed the rubber parts would be worn out / gone). It is however the same dimension as the original part. I was actually thinking of combining 2 stoppers in order to make it stick out more, although an improved design would be a more elegant solution.
Do you know where I can get this upgraded part?
Jonathan
Posted 2 years 2 months ago #200258David
Posted 2 years 2 months ago #200262Thank you for the link. I do not have a problem with that part. It is the 'L' shaped bracket that the stoppers are supposed to come into contact with. Also, it is not with the front stopper, it is at the rear of the door / rear stopper. The problem is the 'L' bracket that is supposed to come into contact with the stopper on the window lift clamp assembly is not making contact. Please see the image below. The rear stopper is part of the window lift clamp assembly
My feeling is that the window runner (not sure if this is the correct term) - the part on which the window clamp assembly slides) becomes slightly distorted at the top over time due the force of the window being pushing against the seals over time. This eventually creates a slight gap between the stopper and the stop bracket. Fixing this distortion with the glass in situ is a delicate. Not sure if I am willing to try this out of fear of breaking the window. I also do not want to take the window assembly apart as I feel that I will struggle to align everything right when I put it all back together. The other alternative is to fabricate an 'L' bracket that is slightly longer on the top.
Posted 2 years 2 months ago #200270I believe that the first diagram is confusing the issue by pointing to two glass stops. There is only the one stop on the glass to contact the front one. Possibly there was an intention to fit a rear stop on the glass but it found to be superfluous. I have adjusted many a window fitment and have never even looked at this rear 'Stop'.
You could be worrying for nothing...
Posted 2 years 2 months ago #200271David
Replied by deepfat on topic Rear window stop adjustment - does not make contact
Posted 2 years 2 months ago #200273Please Log in or Create an account to join the conversation.
Posted 2 years 2 months ago #200295David - I do not question your extensive knowledge and experience with MGF / TFs but I am just wondering why the workshop manual describes the 'L' bracket (under 'F') as 'these give glass height adjustment (this is also the glass stop)', if it does not make contact. Also, there is piece that sticks out of the glass retention assembly - is this not meant to make contact with the bracket? If not, what is it for? Why is the L bracket even there if it does make contact with anything?
Posted 2 years 2 months ago #200303If somebody else has more info on this I'm happy to be corrected.:yesnod:
Replied by Keymaster on topic Rear window stop adjustment - does not make contact
Posted 2 years 2 months ago #200348Have you tried adjusting the blue plastic serrated shim marked G on the diagram. Be careful to mark its position before altering it so you can move it back if you need to.
When slackened off the shim will move up and down which slightly alters the vertical camber. Maybe this will get you the contact with the stop you need?
Bit of a trial and error to get it right or near enough I'm afraid, you will need patience with these adjustments.
