Re:Lights
- Away
In fact if done properly I doubt any of the authoritarian deadshits would even notice, most having never seen one of our cars anyway
You have a valid point though. If the lamp frame were modified to accept legal lamps and those, in turn could be adjusted to create legal beams then there would be hope. I am thinking that thick wiring and low resistance feeds directly from the battery will increase the output by quite a lot and a pair of decent bulbs should do much of the rest. I shall give the beam forming glass a good wash and the reflector a warm and gentle bath in the sonic.
- Johnny the Fox
- Apprentice MGer
I tried to get around this by fitting LED bulbs that mirrored the filament placemat of the original incandescent lamps, but as LED bulbs have now been made illegal to be fitted in headlamp units not designed for them I am back to the originals .
Mind you the light output is still less than would be expected from a modern car.:coat:
- Away
Johnny is correct with his comments on both the mirroring & LEDs, the mirroring deteriorates primarily due to heat, so if your car is an all year round car the likely hood is that your lights will be less good than a summer one.
Some overcome this by fitting higher wattage bulbs * which create more light output, are strictly illegal & create more heat & thus accelerating degradation.
My car seems to have always been a summer car with the silvering being in good condition, however when out after dark I felt the need for a better main beam, I live in a dark skies area, & in between MOTs I fit * Osram 100 watt bulbs, using them sparingly.
Incremental improvements are always difficult to assess as there are marginal gains with each step, one would have to strip back to original & with instruments test a before & after.
- Johnny the Fox
- Apprentice MGer
Retrofitting HID bulbs is illegal, but as far as I can research it is perfectly legal to fit LED bulbs as long as the beam pattern passes MOT specs.I think that the problem with the F is tarnished or heat damaged silvering of the reflectors.
My friend is an MOT tester and his take on it is, LED are not to be fitted to to anything not designed for it so technically illegal but as they are not allowed to investigate, if the beam patern is correct they cannot fail it, but insurance companies can class it as an illegal modification, never heard of it but it makes sense, I use night osram breakers there are plenty of good used headlight units available, failing that have them re-plated but that is the very costly option, bare in mind that the light were never that bright when new but were accepted as most other cars of the day were the same.David Aiketgate wrote:
