Knobs
Why are heater knobs so expensive, even the original Mk1 f examples command silly prices, £50 + for a set of three uninspiring injection mouldings
I was pursuing an idea where I wanted to fit some components behind a knob & being ill prepared to pay an objectionable price I took a punt on £6 worth of repro air con for a ford focus, which when fitted with the steel collar of the originals make a tidy set.
I set up a test rig in the workshop using a similar fan & ran it on 18v for a day with no apparent detriment. You can buy power units of eBay for a few quid that will jack 12v up to 36v if you wish, I stuck with 18 & that accounts for switch position one.
Position two is off & three is continuously variable. I removed the switch & resistor network & replaced it with a pulse width modulation control that gives me any fan speed I choose. So yes behind the knob there's a small board, which acts as a terminal for the "clock" Spring I wound to allow free movement of the controls which sit snugly behind the knob & the LED its current limiting resistor plus the switch.
It hasn't been used in earnest as yet but has proven reliable on "dry" test runs.
I have a picture of the arrangement but it's on another device whose whereabouts is unclear at the moment, I'm not very accomplished at keeping track of my various computers, with the exception of the one in the workshop, which has remained rooted to its spot since I moved a tool chest in front of it.
When it crops up I'll try & post it, try being the operative word.
Sadly I'm unlikely to follow you having just discovered this week that I can't seem to be able to solder 2 wires together! it appears since dad taught me using a big copper tipped iron on the gas ring over 50 years ago things have changed. After much googling I now have on order ROSIN coated lead (naughty) solder and hope this will resolve the issue.
Getting electronic devices in to deceptively small spaces is a specialty of mine, I’m fitting the steering wheel mounted radio controls from a Rover 25 to my car at the moment & because I want to utilise couple of spare ways in the wheel clock spring, I need to mount a circuit board in the wheel itself without interfering with the airbag etc & then interface it all with the radio, which is a Sony.
And no it’s not a straight forward job, not for the faint of heart unless you use all the Rover kit, wheel, cables & radio.
