Re:Step speed gearbox issue
Step speed gearbox issue was created by Davidalan
Posted 1 year 6 months ago #201941
Hiya everyone, I’m new to mgtf ownership and I have an issue with my step speed gearbox
When reverse or drive is selected the car seems to “jump” into gear and is trying to move before accelerating, when it starts moving it seems really aggressive and it’s quite jerky on acceleration also when slowing down it’s really jerky too, has anyone any idea what I need to look for ?
Thank you
Replied by EllisoJo on topic Step speed gearbox issue
Posted 1 year 6 months ago #201950
I am sure I have read somewhere that a thorough draining and re-fill of fresh oil CAN (but not neccesarily does) cure the sort of problems you have reported.
MAKE SURE YOU USE THE CORRECT OIL!!!
Many garages Assume (as in "Makes and ASS out of U and ME" that ATF is the correct fluid. It is most definitely NOT. The Steptronic AKA Stepspeed is a CVT "Continuously Variable Transmission " as used on the DAF Variomatic. BMW added clever electronics etc. to simulate fixed speeds accessible from paddle shifts.
I googled the recommended oil and the picture attached is what came up:
Replied by Davidalan on topic Step speed gearbox issue
Posted 1 year 6 months ago #201951
Thank you, I have ordered the correct oil, I will try this first and see how I get on
Replied by Steve on topic Re:Step speed gearbox issue
Posted 1 year 6 months ago #201952
I believe there is also a filter that should be changed at same time.
by Steve
Replied by Davidalan on topic Re:Step speed gearbox issue
Posted 1 year 6 months ago #201955
Have you any ideas where I can get one please
Replied by Airportable on topic Re:Step speed gearbox issue
Posted 1 year 6 months ago #201975
I fear you might find that problematic. If you look back through recent topics you’ll find reference to this, I recall there were a number of ideas floating about but I don’t remember a conclusion. If you track the post down send the proponents a PM, resolving something like this is better done in a group.
And keep us posted, I’m sure there will be a reoccurrence of this question & to be able to direct future owners to fellow Stepspeeders will only help like minded button pressers.
Posted 1 year 6 months ago #201988
Do you mean finding a filter might be problematic ?
Posted 1 year 6 months ago #201990
Yes I’m sorry, it wasn’t very clear, from my hazy recollection of the post the filter has been disconnected although there’s one for the Mini, which uses the same box however I recall there’s an incompatibility problem which has to be worked around. This is why I recommend contacting other Steppies.
Time to create page: 0.502 seconds
