Strange Passenger window fault
Strange Passenger window fault was created by Alxwood
Posted 1 year 6 months ago #201942
I have noticed a very strange fault with my newly acquired MGF (96).
The passenger window does not function when the headlights or sidelights are on... However the drivers side is fine and once the lights are switched off it functions as normal.
Im not sure if anyone has had any experience of this or any ideas.
Thanks in advance.
by Alxwood
Replied by EllisoJo on topic Strange Passenger window fault
Posted 1 year 6 months ago #201944
Sounds suspiciously like a bad earth. Not sure WHERE, but I would start by examining any earthing points traced back from the passenger-side window switch.
Replied by Alxwood on topic Strange Passenger window fault
Posted 1 year 6 months ago #201945
Thank you, I suspected this may have been the case.
Ateast it will keep me busy over the bank holiday.
by Alxwood
Replied by Roverlike on topic Strange Passenger window fault
Posted 1 year 6 months ago #201946
Yes that would be earth headers LH and RH under bonnet - take a look at this thread where to find them: https://www.the-t-bar.com/forum/roverlike-s-guides/97850-mg-f-tf-earth-points-locations-guide
The following user(s) said Thank You: David Aiketgate, trevtherev, Alxwood
Posted 1 year 6 months ago #201947
Thank you so much for that. I will check it out.
by Alxwood
Time to create page: 0.511 seconds
