Slave cylinder
Hi everyone, I’ve been investigating my clutch problems further and I’ve found a leaking hose under the car.
There appears to be a rubber hose connection bridging to steel clutch pipes.
Q.1 How difficult is it to replace the hose?
Q.2 is there strong possibility that the steel pipes will be damaged in trying to disconnect ?
Q.3 is it good practice to replace the slave cylinder at the same time or is it better to “if it ain’t broke don’t fix it”?
Thanks as always, your knowledge is much appreciated.
Bob
Bob
by Bobb
Bob, firstly well done on identifying the fault. Replacing the hose should not be difficult, accessing the connections each end of the Flexi hose can be difficult if you don't have space. If you use two spanners to hold and release the Flexi pipe there is no reason why you should damage the metal pipes (but soaking with releasing fluid may assist the de-assembly! I would not replace the slave cylinder just because you can. Replace the Flexi hose and bleed the system. If it all works jobs a fish!
by TaffD
+1 for the use of penetrating oil/ releasing fluid. I find a can of Plusgas an essential item.
That, together with the use of good quality spanners, will reduce the risk of rounding off the fittings whilst you are working on them
by Notanumber
The best way to NOT round off the nuts is to use the correct type of spanner……… “which is that?” I hear you ask
The correct spanner for brake and fuel lines is a flare nut spanner.
Below are some pix of mine
There are both metric and imperial sizes in the pic above, you’ll notice that they grip around the nut and as such tend not to round the nut off like a normal open end spanner. The fancy ones in the tool roll have a ratchet action.
These are of a crows foot design which are handy if you don’t have the swinging room. They are 3/8” square drive, so whack on you socket extensions n’ ratchet and away ya go!
- trevtherev
- Journeyman MGer
Yeah, can't second enough the use of brake spanners and crows foot for that nut that seems to be where no one would put it.
by trevtherev
Flared nut spanner is definitely an alpha plus plus tool, I’ve never used crows feet although my lad has a set laid out as per Cobber.
by Airportable
Thanks for your insight. It turned out to be a faulty slave cylinder, which was the easiest component to change.
I bought the whole 3 part section from a scrap yard, the flexi pipe, clutch pipe and slave cylinder for £45 in preparation.
Bled the system with a Gunson easibleed kit.
Piece of cake... almost
by Bobb
Thanks for reporting back, it’s a habit that all contributes should get into. It confirms to the advisors that their advice is correct, it guides those who might be facing a similar problem & it reenforces Talkingcars subscript “MG the friendly mark”.
Tah, Mike.
Tah, Mike.
by Airportable
Time to create page: 0.547 seconds
