temporary binnacle repair
Is there any advice on a quick and dirty temporary fix that will just stop the curved edge (front of car end) of the binacle rattling over every bump ? Doesn't matter if it leaves visible clips, screws or adhesive tape showing: the binacle has some damage on one side of the curved edge so will have to be replaced or repaired properly when there's time.
For now I just want to silence the rattle quickly- I've spent much more time working on the car than driving it since I've had it so just want to drive it for a bit without the rattle as a soundtrack.
For instance the repairs described all seem to focus on keeping it as a detachable part but it strikes me that it's not a part that anyone would actually need to remove. Unless I'm missing something it may as well have been part of a large one piece dash moulding and was only made as a separate piece for ease of manufacture, not because it would ever need to be separately removed. As such, can it be permanently sealed to the dash or is there a strong reason to avoid this ?
- trevtherev
- Journeyman MGer
There’s a lot of space under there & I find it a useful place to tuck my supplementary electronics, the space behind the centre air vents is another useful hiding place. Changing a dash lamp would remain undone if I couldn’t remove what I consider to be a cover.
On another note, a few days ago I said that I wouldn’t be posting, however the more observant of you will have noticed that I’ve been as verbose as usual. Instead of walking the byways & field paths of Hertfordshire I managed to get a tummy bug which has laid me low, the only walking/dashing I’ve been doing has been between my bunk & the bog & that view is somewhat tiring by now. As usual you are all good company when I can’t reach my spanner’s
One thing to note as you have the off side vent out is the clear view you have of the OBD port, I’ve reposition mine by making an extension, but prior to that, rather than root around in the fuse box, I’d pop the vent out & plug in via that, a couple of seconds as opposed to a couple of minutes of contortions.
