MGF/TF petrol cap
MGF/TF petrol cap was created by g4wam
Posted 1 year 6 months ago #202357
Hi all,
wonder if anyone has removed the key lock assy from a filler cap?
I can buy a new filler cap without lock -which suggest the keylock can be swapped over.
my old filler cap isn't sealing properly and i am fairly certain a new seal is not available as a spare part.
thanks
Mike
by g4wam
Replied by Toyman on topic MGF/TF petrol cap
Posted 1 year 6 months ago #202361
https://www.the-t-bar.com/forum/22-cjjs-guides/14345-fuel-filler-cap-how-to-change-the-lock-barrel
In the How To Guides up the top
Cheers
John
by Toyman
The following user(s) said Thank You: g4wam
Replied by trevtherev on topic MGF/TF petrol cap
Posted 1 year 5 months ago #202363
It can be swapped over and is not too bad a job. I used the excellent guide as Toyman points you towards, I think the only bit I found a tad worrying was releasing the two end lugs, but otherwise it is very doable. I removed my cap to get the filler cap chrome plated after I had some fun and games with a mate who had removed his some months previously and brought it all around in a box to assemble.
Replied by Airportable on topic MGF/TF petrol cap
Posted 1 year 5 months ago #202369
I had mine in bits a short while ago, the steel clips holding in those silly socket head studs had rusted away & I thought I’d lost one. I made brass M6 inserts, drilled out the original hole to accommodate the inserts & glued them in & with a set of cut down M6 socket head screws fitted it all back together.
Again I made my own inserts because I have the tools but you can buy them off eBay; Brass threaded inserts got me straight in. You can buy coloured screws so could colour coordinate if you wish. After I’d finished I stood back to fully appreciate my handy work & found the lost inserts.
Replied by Notanumber on topic MGF/TF petrol cap
Posted 1 year 5 months ago #202371
I'd always wondered what the allen key headed studs were for on the petrol cap. I suppose i should be grateful they dont all need unscrewing individually to remove the cap.
That got me wondering about the finisher sections either side front of the bootlid. Are these bits and the bolts within them just decorative as well ?
Last Edit:1 year 5 months ago by Notanumber
Last edit: 1 year 5 months ago by Notanumber.
Posted 1 year 5 months ago #202372
The torques screws are real enough but if you have VVC wheels the naff mock socket headed “screws” are plastic. If you are a real nerd you can drill & tap (M6?) & you can get black stainless cap head screws to get you back to where you started from. Only now you have convincing screws which still do nothing.
Replied by Andy661 on topic MGF/TF petrol cap
Posted 1 year 5 months ago #202373
I replaced my filler cap by swapping the lock over... little bit fiddly but it can be done!
by Andy661
Replied by Cobber on topic MGF/TF petrol cap
Posted 1 year 5 months ago #202375
That’s gotta just shit you to tears!
Replied by g4wam on topic MGF/TF petrol cap
Posted 1 year 5 months ago #202384
thanks everyone who answered my query
regards
Mike
by g4wam
Time to create page: 0.541 seconds
