Warning lights and indicator clicks
- billcoleman
- Journeyman MGer
Increase the volume of the indicator clicks.
Increase the brightness of the warning lights in the dash pod.
Replied by Airportable on topic Warning lights and indicator clicks
Posted 1 year 7 months ago #202418On the indicator problem, this is exasperated by advancing years & again eBay is your friend. If you are a farter about as I am you can fit a sounder to enhance the indicating experience. Miniature sounders off the aforementioned mass emporium coupled to a bridge rectifier can easily be linked into the system.
Pop out the middle vent then pop out the emergency indicator switch, pick up the green/red wire & the green/ white wire & connect those to the A/C on the bridge. Take the positive terminal on the bridge to the positive on the sounder & run the negative to ground. Attenuate the racket from the sounder to taste (several layers of gaffa if are young, may be required, fewer as you age) & reassemble.
As usual when a quiz question like this comes in I’m miles away from my diagrams so check the colour combinations by visiting the circuit diagrams found in the Community section.
* these are polarity conscious so expect a couple of tries.
- billcoleman
- Journeyman MGer
Replied by billcoleman on topic Warning lights and indicator clicks
Posted 1 year 7 months ago #202419For the indicator clicks, today I should be receiving a pack of 5 from Amazon. One was needed for the reverse sensor sounder, so I'll have some left over for the indicator.
- billcoleman
- Journeyman MGer
Posted 1 year 7 months ago #202427Please Log in or Create an account to join the conversation.
Posted 1 year 7 months ago #202428Please Log in or Create an account to join the conversation.
- billcoleman
- Journeyman MGer
Posted 1 year 6 months ago #202694Is this the same on all TF's or is this because mine is an LE500?
I don't really want to go that deep into the electronics in case I damage something. All the plastic parts (trim etc) on the LE500 are very lightweight and feeble. In my opinion, these parts are all low quality - basically white plastic spray painted black. Are earlier TF's like this?
Posted 1 year 6 months ago #202696I've a sacrificial set of instruments tucked away, I'll root it out & post pictures later.
Posted 1 year 6 months ago #202697The lamp has wire terminals folded back over the moulded part of the envelope & these make contact with the copper contacts which also form the wiping terminals on the board.
The yellow lamp is a led, used during a failed experiment, the white ones I used were little more than the bayonet base with a square chip mounted on top.
- billcoleman
- Journeyman MGer
Posted 1 year 6 months ago #202700I assume that I need to remove all the little socket head screws and split open the cluster to get to these lamps.
Posted 1 year 6 months ago #202704This is modus operandi for the f as illustrated, I can't see SEAC changing that system for 500 cars.
