Indicator problem after heavy rain.
Upon starting and driving home, the indicators didn’t work: absolutely no response to the stalk switch in either direction, nor the hazard switch. Roughly 25 miles home, in the early hours of the morning, with little traffic around, I tried the switches repeatedly, and after about 15 mins the hazard switch illuminated the little red warning light, but nothing else. Just before I got home, indicators and hazards started working as normal.
I’m thinking something got wet, and dried out on the way home, but what was it!?? It’s all fine now, but I’d like to do some preventative maintenance to stop it happening again.
Replied by Notanumber on topic Indicator problem after heavy rain.
Posted 1 year 4 months ago #203555Take time to download the manuals and wiring diagrams from the Community, Downloads section of this site and also refer to the How Tos. If it is water ingress then you need to know how to stop this. You will also discover the location of the hazard and indicator flasher relays so that you can get them out and make sure they do not have residual water inside them.
Replied by Airportable on topic Indicator problem after heavy rain.
Posted 1 year 4 months ago #203591Whilst coasting towards an MOT my system failed & could find nothing locally as a replacement; the nearest was in Manchester.
With the MOT sorted I looked at the old relay & found two dry joints, having resoldered them I now have a spare.
The part number is YWT10003 & lives in the fuse board under the steering wheel. At least it does on my f.
I’m struggling to find the flasher unit, can anyone give me a pointer?
Check the hazard switch it could be your problem.
Check under bonnet fuse #4.
Check fusible links #6 & #5
Check interior fuse #23
That’s all there is on the subject, sorry I can’t be of more help.
As I’ve mentioned elsewhere the manual was written not by someone with mechanical aptitude…. No it was written by someone with mechanical ineptitude!
Still now that phone books are a thing of the past, the police could use the manual as a substitute for interrogation purposes ( belting the living shit outta suspects with the phone book leaves no bruises and doesn’t hurt your hands.)
Posted 1 year 4 months ago #203702I’m guessing now & I’ll see if I can verify this theory but there appear to be two standard relays doing the job & my guess is that the Pektron unit is controlling them.
I’ll check tomorrow & post back, unless I’m pipped by the Knowledgeable.
Posted 1 year 4 months ago #203703Sorry if you were mislead but I would be contacting Paul at Technozen & see what comments he has to make.
If not, I would suspect the hazard switch and flasher unit.
If yes look at the indicator switch, although its theoretically possible, I doubt both of those relays shit themselves at the same time.
As I mentioned check the fuses and fusible links mentioned not just having a squiz to see if they’re blown but check that there is no corrosion on the lugs or the connections.
Check all the wiring connections and the earthing points.
They seem to have taken a simple system that has stood the test of time, and made it unnecessarily complicated for no good reason, other than they could.
You had an indicator switch, a flasher unit, a fuse, some wires and some lights…… to add hazards to the system you had a hazard switch another flasher unit, wires, a fuse and some diodes to keep the left and right indicators separated when the hazards are not in use………hardly rocket surgery or is that brain science?
Replied by Roverlike on topic Indicator problem after heavy rain.
Posted 1 year 4 months ago #203706As Airportable said if you have Pektron system (oval fob with logo in the middle) BCU unit operates thes two indicator relays and your best call would be to Paul @ https://www.technozen-electronics.co.uk/ since this well might be Pektron BCU problem.
