heated rear window wire run?
heated rear window wire run? was created by Notanumber
Posted 1 year 4 months ago #203851
The heated rear screen on my new hood didn't come with the loom attached. It's easy enough to wire up but what is the right way to run the wire to the terminal on the far side of the screen. Theres nothing obvious to anchor it to stop it dangling. Should the wire be glued along the top or bottom edge of the screen ?
Replied by Airportable on topic heated rear window wire run?
Posted 1 year 4 months ago #203855
That’s what I’ve done, little dobs of cyanoacrylate every few inches (other measuring increments are available but rarely fully understood by persons over a certain age).
Replied by Notanumber on topic heated rear window wire run?
Posted 1 year 4 months ago #203862
Thanks. Did you run it above or below the glass ?
I will have to buy some cyanoacrylate. Is this the stuff you recommended for repairing the instrument binnacle cowling ?
Replied by mowog73 on topic heated rear window wire run?
Posted 1 year 4 months ago #203863
I have the same problem with running the wire on the hood on my wife's F, there is nothing to anchor it to.
Would you happen to have a picture showing the wire glued in place?
[size=10pt]Mark[/size]
95 MGF
by mowog73
Posted 1 year 4 months ago #203869
We’ve just returned from a run around some of the nice bits of Yorkshire, it’s always good to take a look at what an extended Lancashire would have looked like if the War of the Roses had turned out differently.
It rained on the way back so the hoods wet, I’ll let it dry & then I’ll have a photo session. Cyanoacrylate is the Sunday best name for super glue, I use it in conjunction with an activator which accelerates curing from minutes to moments
Posted 1 year 4 months ago #203871
Does the wire run above or below the window ?
Posted 1 year 4 months ago #203872
At the end of the day it’s entirely up to you, I ran mine beneath the window along the rubber, hopefully the photos will explain my methodology. The watchword with any adhesive is cleanliness & the accelerator helps before & after application. I use it to clean both surfaces prior to the big stick, this chemically cleans the surfaces & always prepare a mechanism to hold both workpieces together once the adhesive is applied. If you want a quick stick another squint will fix in an instant, however I have an instinct that is a more brittle fixture than allowing the cyno’ to cure as a matter of course.
Lecture over.
Last Edit:1 year 4 months ago by Airportable
Last edit: 1 year 4 months ago by Raccoon. Reason: pics inserted
The following user(s) said Thank You: mowog73
Posted 1 year 4 months ago #203873
Thanks. That looks neat. I will go for the same
Posted 1 year 4 months ago #203892
Fantastic Mike, thanks, this is really helpful.
95 MGF
by mowog73
Posted 1 year 4 months ago #203895
Your welcome chaps, it's always good to pass around ideas.
Time to create page: 0.635 seconds
