Noisey unlocking
However sorting door lock/s should be done as soon as possible.
The f doesn't use a PLEKTRON SCU body controller which have the relay issues.
I am not aware of F's having relay issues
mike
Information like this adds to the general wealth of knowledge within the ‘bar & to pool that is one very good reason to contribute.
Every contributor could bring that nugget of information or encouragement that would profit another. One only has to think back a day or two & consider Notanumber & his query on wing removal, a swift response changed his outlook, resulting in another job well done.
Thanks Mike.
Thanks for all the information.
After or while having the door handle failure... (DIY mending huge screw solving it)...
MGTF / Lucas fobs...
Never could get out the door handle mechanism!
So, didn't even change the door locker. Might remember, it disappeared within a couple of months...
As spares, I have the door locker & a Trophy yellow handle... Make offer, if required!
Anyhow, howto is here: https://www.the-t-bar.com/forum/54-how-tos/92793-how-to-change-a-door-lock-mechanism
MGF are different in that they have a single cable on the driver /passenger side-no reversing wiring (SCU relay)for the superlock
MGTF have 2 cables on the driver side and the passenger side-reverser wiring (SCU) relay for the superlock
Internally they are the same-(bold statement from me)
I had a whole load of info and dissection pictures on here but cant find them anymore.
The main failure on door locks is the microswitches which can be cleaned after lock dissection
I you have a TF and it has deadlocked on the passenger side -the fault more that likely will be the SCU superlock relay and not the lock mech (another bold statement from my experience)
regards
Mike
But i never wanted that scenario to happen again so cut the wires to the super lock part of the passenger door lock..
mike
I have purchased a new mechanism for drivers door but also removed central locking fuse to avoid being locked in ,this means I can unlock drivers door with key but still need to press fob to disarm alarm.
Being without central locking on a car with only two doors and rarely with a passenger is fine for now.
- Psychicfrog
- Novice MGer
Thanks
