Upgrading n updating
Very good to all colleagues!
I keep getting details out of my 97 MG F.
Mike Satur's suspension was 35 cm in front and 31 cm in the rear (from the wheel arch to the bottom of the hub)
I have already left it at 35-34 front-rear.
I still have problems with the rear stabilizer bar (photos attached). I think it is mounted incorrectly on the rear supports. I'll check it again tomorrow.
The gas gauge still doesn't work (I've checked the trunk shut-off switch) and I suspect it's the gauge.
I will keep you updat ed!!!
Last Edit:2 years 3 weeks ago
by VJSantos
Last edit: 2 years 3 weeks ago by VJSantos.
For the Mike Satur kit, the ride height should be 320mm measured vertically from the wheel centre to the wheel arch. I don't know how that translates if measured from the bottom of the wheel hub.
Vi más complicado sacar el centro "exacto" de la rueda.
Dado que la tapa del buje es de 42-44 mm. 32+22 mm es la medida que me comentas, alante le he dado 1cm más.
Sigo teniendo el problema con la estabilizadora, está clavada en los soportes de la suspensión.
by VJSantos
También hay un engrasador en el antebrazo. Comprobar si están engrasados.
by David Aiketgate
Last edit: 2 years 3 weeks ago by David Aiketgate.
Both of our Fs have MS' FCCKit. Both cars have the 2ame ride height of 325mm front and rear.
I can't recall what the rear stabilizer set up looks like, but it appears that the plate has been installed, allowing the rear stabilizer to be installed further back, which is correct.
[size=10pt]Mark[/size]
95 MGF
by mowog73
The following user(s) said Thank You: VJSantos
Anything new?
I'm having problems with the rear suspension with this!!!
by VJSantos
Time to create page: 0.494 seconds
