MGF Mk2 Battery discharging overnight
I have heard that one of the relays associated with the ECU has been known to stick closed, but I have not found any further information, such as which relay, what circuit is it associated with, etc.
Replied by Notanumber on topic MGF Mk2 Battery discharging overnight
Posted 1 week 1 day ago #207349As part of your fault finding I would fist reccommend a cheap digital voltage gauge and wiring it ideally to come on with the accessory position of the ignition switch (radio feed) . There are several types available from Ebay and actually they dont look bad as a permanent fixture, about the same diameter as a cigarette lighter socket.
That way you will be able to see if there has been a bit of a drop overnight but just not enough of a drop to prevent starting.
Notanumber wrote: Its a tricky one because the fault is inconsistent.
You can get voltage meters the can just plug into the ciggy lighter socket, saving a bit of buggerising about.
But I agree with the idea of first checking for wiring insulation damage!
Replied by Airportable on topic MGF Mk2 Battery discharging overnight
Posted 1 week 1 day ago #207358There is a shut down sequence which resets all circuits down to a quiescent current of around 250ma (this was the value on my car a couple of days ago). Even inexpensive digital multimeter have a 10amp range, once this range is selected, it can be introduced in series with the battery & a useful indication of the current being drawn indicated.
Don’t try & start the car with this connected, it will melt in a most impressive fashion.
Airportable wrote: It’s not as much the voltage that requires monitoring, it’s the current.
I have a simple in line ammeter that plugs into the fuse holder, this allows you to see the current leakage through individual circuits. Actually I have 2 one is 20 amps and the other is 60amps.
You do need to make sure everything on that circuit is turned off, then you use it to replace the fuse and you can see how much current draw is through that circuit. if every thing is off then the reading will indicate not only a leakage but also it's magnitude.
Posted 1 week 1 day ago #207362M
- BruceTF135
Replied by BruceTF135 on topic MGF Mk2 Battery discharging overnight
Posted 6 days 17 hours ago #207383Ebay item number: 264539496409
