Engine cuts out at circa 4000rpm
The engine in the TF has occasionally taken to cutting out at around 4000 rpm not every time or even every day. The first time it happened to me was soon after the gear cable clip and clutch bleeding problem, I was accelerating up a motorway slip road and when the revs got to around 4000rpm the engine just cut out, when the revs dropped to around 2500rpm it picked up and performed perfectly for the rest of the journey home. For the last week or so I have experimented and it only happens when I accelerate hard, if you don’t floor the accelerator it doesn’t seem to happen. It doesn’t happen every time you accelerate hard either so the previous observation may not be correct. My wife had it happen to her on two occasions before we lost the gear cable clip so I think we can discount any interference to anything when bleeding the slave cylinder. Other than this irritation the TF is running really well, any thoughts?
by MGB281
Breaking down under load sounds like an problem with the ignition system, so I'd give that a good onceover first and of course hook it up to a Pscan or a T4 to run diagnostics.
See how you go with that and get back to us with your findings.
Of course if, as our dear friend from the antipodes recommended, it isn’t the ignition, it therefore has to be fuel.
I’m not adopting a voice of experience, I am, however, reflecting on the number of odd faults created by a failing fuel pump.
A short while ago a member was having problems & there was a lengthy discussions on what he was experiencing; a new pump was recommended & I think fitted, subsequently everything went quiet.
Did that indicate success?
It’s worth a thought.
by Airportable
Thank you both for the replies, I was going to swap over the ignition leads and if that failed the coil packs first. I have spares of both, the leads that are fitted were new in 2018.
by MGB281
Time to create page: 0.411 seconds
