Rear window sealing strip
Morning I`m about to start fitting a replacement window in my TF is there a special foam strip or can you improvise .Also started to refurbish wheel which were quite marked .Just waiting to collect spray tin of Anthrasite grey to see what it looks like .So keeping busy Len
by digcot65
The original foam is pretty naff. I used a strip of the loop side of velcro. Much more resistant to rotting/ falling apart.
Anthracite is very deep blue tending to black. Like my car.
Re-fitting a replacement rear window ,it seems the end holes on the window seem to need extra long pop rivets Non of mine are long enough to go through the metal strip the window surround and the large metal hoop Len
by digcot65
Ive held the window metal strip and frame tight together with Mole grips and pop a pop rivet in slowly but surely another job being done .Len
by digcot65
Morning managed to order some 3.2mm x 16mm pop rivets ,so I`ll know they are going through the 3 layers they need to Len
by digcot65
Time to create page: 1.126 seconds
