TF inlet manifold.
Any help/advice will be greatly appreciated. Regards Glyn (D4KGP)
I have recently changed the manifold for a 4-2-1 & new flexible pipe, so I was faced with that concern.
Plus gas, plus gas, plus gas, leave to work, GOOD socket, not too long a bar & ease to break stiction.
To take the head off with the pipe work attached will make the assembly heavier & unwieldy.
Catch the rear wing with the manifold & you’ve a paint job to do after the engine is back together.
Many thanks Glyn.
Thanks for replying. Glyn.
Obviously when I’m on with a job I can consider the minutiae of the work in hand, whereas comments on here have to be broad brush strokes.
I would be taking the manifold off, after all I would guess the head gasket kit will come with a replacement.
It’ll be interesting to see what others think, I am one of many & not all of my thoughts chime with some of the more “dynamic”contributors & there in the word “dynamic” or lack of dynamism is my observation on getting old & slower.
It’s the lack of feedback that I find difficult to come to terms with, a spanner or socket talk back to you & with experience the situation can be interpreted.
Are you being told that the recalcitrant nut is coming loose or is the bolt shearing.
Cobber is the King of stuck & broken hardware, I wander what sage advice the great man would hand down?
We’ve not heard from him recently, I do hope he’s OK.
Come on Cobb’s give us a call.
For inlet manifold nuts I suggest a 1/4" drive socket set with a variety of different length wobble bar extensions (ball ended to let you undo the nut from awkward angles)
Inlet manifold nuts shouldn't be too tight to get undone using the right tools.
Exhaust nuts may well be a bit more troublesome, especially if some knuncklehead didn't use anti size on them during assembly
For those of you not familiar with wobble bars the following pix might help explain:
My comments on rattle guns was a general one & not specific to this job, other than the crank bolt.
Thanks Glyn.
You will need to split the inlet manifold to get the head out. That is, the plenum chamber and upper manifold needs to be unbolted from the lower section. You will probably need a new gasket to replace it.🫡
ADDENDUM
Once you split the manifold, the head comes out with the lower section still attached.
This is the method the travelling mechanics use. You are just creating needless work taking the entire manifold off.
