Cleaning under the bonnet
New owner and first post - please be gentle!
iIt looks as though the bonnet area of my 04 TF has never been touched, and needs a good clean. Can I ask how you folks do it, as I don’t want to get water/cleaning product anywhere it shouldn’t. Thanks in advance.
Snapper.
Snapper.
by snapper41
Hi and welcome to the forum.
I would probably take out the tool kit and spare wheel, remove the battery and cover the fuse box before getting busy with a hose.
Not much to worry about at the front end..
Welcome and greetings.
Jobs to do whilst cleaning under the (front) bonnet:
1 It's worth removing the wide black plastic by the bulkhead to clean under there. Also
2 check the flexing of the firewall by the brake servo/master cylinder (it's on the passenger side) whilst getting someone to push the brake pedal. If there's much movement there it could be worth adding a servo brace. They aren't expensive and will improve your brake feel.
by Notanumber
- judiths handyman
As far as cleaning fluids themselves go, as a cyclist I found MUC OFF very good, it removes rubbish inside and out to great effect.
Time to create page: 0.649 seconds
