Just found my TF's carachter.
Afrer reading the thread about the boot wiring I was curious about mine. Sleepless nights meant I just had to look.
I removed the tape and gently opened the plastic trunking. Perfect!
I could see what David meant about the bottom hinge clip so I removed it. I cleaned up the tape and the tubing with alcohol, not the drinking kind, and re taped it up. It looked really neat so with a smug smile on my face I checked II had the keys in my pocket and closed the boot. Job done.
As I walked past the drivers door I pressed the Fob to lock it but I heard no click.
It's ok I thought, somebody had posted you have to be almost cuddling it. So I cuddled it and nothing.
Hmm...jumped in the car and no ignition lights. Nothing.
PANIC.
Sat for a moment, it can't have been anything so major I had disrupted in the boot.
Opened the bonnet to check the batery terminals and the earth terminal is sat on top of the post!
Phew..easy fix. Sorted that and I had ignition lights. Got out of the car and pressed the fob to lock it. No flashing indicator lights or clicking door buttons. Clicked it again and the alarm light went out..hmm..jumped in the car and started the engine. Started ok.
Switched off the engine and tried the fob to lock it and it worked!
Now you all know the battery is under the bonnet and nowhere near the boot wiring.
Anyway it all seems to be working.
It's defnitely got character!
So now I am going to find a twig and thrash it.
PANIC.
Last Edit:2 days 10 hours ago
Last edit: 2 days 10 hours ago by TA22GT. Reason: Poor spelling.
Its asked for it
Shut your eyes and it will become a red Austin 1100 Countryman in Torquay
Last Edit:2 days 8 hours ago
by Notanumber
Last edit: 2 days 8 hours ago by Notanumber.
Well after the damn good thrashing it got its own back again.
Went in to Halfrauds to buy a socket set. Got out the car and pressed the fob to lock it and the alarm/horn went off at 300 decibels.
Everyone is looking.
Pressed the off and it went off so I left the car unlocked.
On the way home I pulled over in a quiet layby and tested the fob and this time it locked! Damn car.
I still have the twig in the boot and it knows it.
Its asked for it
Shut your eyes and it will become a red Austin 100 Countryman in Torquay
Well...she is now called Sybil!
Time to create page: 0.499 seconds
