fuzzy fuses...
Incidentally fuses, especially those of the blade type as found in our cars, can sometimes appear good at a quick visual inspection but can actually be no good,as corrosion can be the problem, there can be a build up of oxidization on the blades inhibiting the current flow or even a corroded through filament where it is hard to see.
Some times they've been running hot without actually blowing but the fuse body is all distorted and sort of melted with prolonged exposure to heat
As Cobb’s has said have a look at that & I’ll have a look at the circuit diagram to see if there’s a common denominator.
For your info, it's about a TF from 2002 LHD. Fuses are situated under the steering column.
Great stuff.
Fuse 12! The wiring diagram shows that circuit on F3, is your car on the pektron electronics or the Lucas? The thumbnail of the car shows a tf, I assumed it would be a pektron car in which case it would be 3, on the Lucas system, as you have found out, it’s 12.
Great stuff.
How do I tell a Pektron from a Lucas please..2002 TF..thanks.
lucas- square fob
Pektron - round fob
lucas- square fob
Mine is square...better or worse?? 😁
