TF spare wheel tyre size.
I understand it would also have to be a multidirectional tyre. (16 inch wheel) Thanks Glyn.
- generous_dad
Front - 185/55R15
Rear - 205/50R15
Spare - 175/65R14
It is possible if you are running four pots & have a front puncture to take a wheel off the rear & transfer it to the front, that would allow you to use the standard spare on the vacant rear.
This is not something I would wish to do on a high volume road.
As the car is still new to me I take it that because my callipers are red they are 4 pot on the front, yes?
Thanks Glyn. (I have 16 inch wheels)
I find that I'm getting more confused about this. If I purchase a 11 spoke 16 inch wheel surely that would fit both front and rear
as a spare, so going back to my original question: what size tyre would be required and would it need to be multi directional?
Thanks again. Glyn.
If your rear tyres are different do the same and you will see they are close.
Find a 16 inch rim that fits, doesn't have to be alloy and type in tyre sizes until you find a size that suits your circumference.
As above...when I had wide tyres in 15 inch on my rally car I had to fit a 14inch wheel and tyres to match the different front to rear sizes on my car.
Do not persevere with sealant. It will bite you.
As has been said this can dump you in some deep shit, if it all goes tits up, as yet this hasn’t happened & I’m not dumb enough to think it won’t. Plus it’s easier to lift a box of chemicals out than a tyre, as I’ve two knackered shoulders one is more attractive than the other.
If you have standard rear brakes, then the 175/65/14 would overcome your problem but as I have said to change a front flat you have to take a rear wheel off first.
Does a 16” wheel go under the bonnet?
There are also 2 pots which look like the fours only washed at the wrong temperature & put through a spin cycle.
17 inch wheels! You little rebel!
For rebel read daft bugger, but at the price & shod with new proxy tyres I’d have been daft not to have bought them. It was a lovely day out & a really nice man selling them.
If their both knackered, it's likely neither are all that attractive.I’ve two knackered shoulders one is more attractive than the other.
Some were yellow and some black and I understand that they are the same part/casting number as a standard 16 inch. Glyn.
