Idle surge
Idle surge was created by 1275rob
Posted 1 year 7 months ago #209802
Hi folks I’m after some advice. I have a 1.8VVC fitted with a 48mm alloy TB & aftermarket air filter. I have recently done a full service, fuel filter & cambelt change. Car starts fine, warms up correctly & drives good, problem I have is at idle after warm up I get a surge now & again up to about 2K & if left longer the idle becomes rough & stalls. I have another VVC & have swapped the IACV & reset it & also the TPS & it’s still the same. Any advice would be welcome, thanks.
by 1275rob
Replied by Roverlike on topic Idle surge
Posted 1 year 7 months ago #209803
When that happens have you tried to disconnect both hydraulic control valves - solenoids and see if that will resolve the problem? If it does you have 2 solenoids which needs replacement.
The following user(s) said Thank You: 1275rob
Replied by 1275rob on topic Idle surge
Posted 1 year 7 months ago #209804
I’ll give that a try, thanks.
by 1275rob
Posted 1 year 7 months ago #209829
Well I tried it but it was the same, however whilst rooting around I found that my air temperature sensor was unplugged from the inlet manifold & someone before me shorted the plug terminals together, no idea why. Anyway I have plugged it back in & it’s running okay now.
by 1275rob
Replied by Notanumber on topic Idle surge
Posted 1 year 7 months ago #209841
Well done for finding the cause. I wonder why that had been done.
Have you got any more work planned on the car?
Posted 1 year 7 months ago #209995
Sorry for my late reply, I’ve been away. Done quite a bit of work, changed front lower wishbones & bushes, all drop links & arb bushes, new back box, ns rear sill welded, underside under sealed & cavity wax to box sections, loads of other little jobs. I’ll get it mot’d soon & see how I get on. It’s been off the road for about 8 years but it’s a nice car & deserves to be saved.
by 1275rob
Replied by TA22GT on topic Idle surge
Posted 1 year 7 months ago #209996
From what you have done and are planning to do you will have a great car soon!
Good luck..hope all goes well for you.
Time to create page: 0.885 seconds
