ISSUE WITH ALARM LUCAS 5AS KEY
ISSUE WITH ALARM LUCAS 5AS KEY was created by Rekkas
Posted 1 year 7 months ago #209889
Good day,
I would like to share/ask something regarding my alarm key, type Lucas 5AS of my MG TF model 2003.
Unfortunately I run out of battery for some days and because I wasn't home can't noticed.
Now I change battery but car not start, probably need to re-program key and immobilizer but the issue
is that I don't have EKA code, I bought the car from other person and didn't provide me this code.
Where I can request this code, my home is at Athens, should contact Land rover authorised
dealership/sealer?
Thank you
by Rekkas
  • EllisoJo
Replied by EllisoJo on topic ISSUE WITH ALARM LUCAS 5AS KEY
Posted 1 year 7 months ago #209890
whenever you change the battery in the fob OR the 12Volt battery in the car, you must re-synchronise BOTH fobs, by rapidly pressing the LOCK button on each fob, while it is near to the car.
Hopefully, you left the car doors un-locked. If so, I suggest you do this re-synchronisation sitting in the car. It should work with the fob outside the car, as long as you are very close. I do this every spring after re-connecting the main battery, which I always disconnect when I take the car off the road for winter.
You should hear the locks activate after the third or forth rapid press. I THINK it is possible to recover the correct EKA for your car using PSCAN software with a suitable computer plugged-in to the data port. Hopefully, there is someone in Greece who can help?
Replied by Rekkas on topic ISSUE WITH ALARM LUCAS 5AS KEY
Posted 1 year 7 months ago #209892
Dear Sir,
Many thanks for your reply, just one more thing, door must be close and it's to push LOCK or UNLOCK button?
by Rekkas
  • EllisoJo
Posted 1 year 7 months ago #209893
As I said:
"by rapidly pressing the LOCK button on each fob, while it is near to the car."
Replied by Martinr on topic ISSUE WITH ALARM LUCAS 5AS KEY
Posted 1 year 7 months ago #209960
From my Rover handbook.   Car has Lucas 5AS
Last Edit:1 year 7 months ago by Martinr
Last edit: 1 year 7 months ago by Martinr.
Time to create page: 0.497 seconds
