Mystery plug
Replied by 1275rob on topic Mystery plug
Posted 1 year 6 months ago #210307
Hi its a 1997 Mk1 VVC
by 1275rob
Posted 1 year 6 months ago #210308
Hi the wires are red & black, they come out of the main loom which runs into the ECU
by 1275rob
Posted 1 year 6 months ago #210309
Its a Mk1 VVC, the plug and cable don't look aftermarket and looks OEM and as aged as all the other wiring, it would be good if someone could check their cars and see if there a similar plug
by 1275rob
Replied by Airportable on topic Mystery plug
Posted 1 year 6 months ago #210310
Right Rob, I’m up for that as my car is the same but one year younger & I’m interested.
The following user(s) said Thank You: 1275rob
Replied by Roverlike on topic Mystery plug
Posted 1 year 6 months ago #210315
The only connector that I see fit the shape on your picture is purge control valve on charcoal canister. However wire colours do not match: brown/pink and yellow/orange.
But in this scenario you should be missing connection on purge control valve. Do you miss it?
Posted 1 year 6 months ago #210317
I dont think so but I will double check later as im at work now
by 1275rob
Posted 1 year 6 months ago #210320
I have nothing dangling out at that side of the relay frame. There is the connector for the inertia cut out but the wires are brown & the connector is different.
The wires being red & black, the historic positive/negative is also odd on an original fitment auxiliary. I think you have a foreigner.
Replied by Notanumber on topic Mystery plug
Posted 1 year 6 months ago #210336
I'm wondering if it could at one time have been to connect to a lead, thats no longer there, for an exhaust flap actuator which only existed on some early original exhausts.
Posted 1 year 6 months ago #210339
The noise flap came along on much later car & it came about due, in no small amount , to another Squad, the Noise Abatement Squad. In all probability this squad would cycle around, hiding behind trees & in hedges, with their noise meters, accusing certain manufacturers under the noise abatement order.
MGR Just bunged up one exhaust until the car got just as far enough away as to reduce the sound pressure level to acceptable amounts, it then opened & the car sped away.
It’s a good thought though.
Posted 1 year 6 months ago #210342
Definitely not that but similar
by 1275rob
Posted 1 year 6 months ago #210343
My bad, the wires are actually brown / black which is live with ignition & a black earth. Did Japan spec have anything different, my headlights have rover Japan part stickers but I dont have any history for the car to confirm.
Last Edit:1 year 6 months ago by 1275rob
Replied by BruceTF135 on topic Mystery plug
Posted 1 year 6 months ago #210347
Are you sure that isn't orange/black?  Brown is usually much darker.
Last Edit:1 year 6 months ago by BruceTF135
Last edit: 1 year 6 months ago by BruceTF135.
Time to create page: 0.404 seconds
