Guess what - HGF
Replied by Cobber on topic Guess what - HGF
Posted 1 year 5 months ago #210843
Looking at your picture, it doesn't look promising!
There is no way of really diagnosing a warped head without removing it and putting a straight edge across it, you can use a compression test, a cylinder leak down test, a sniff test or a coolant system pressure test to diagnose a failed head gasket, and they can indicate other possible combustion chamber problems such as a cracked or warped head, a unseated, cracked or porous cylinder liner, but the only way to know how bad the problem is, will require removing the head to be sure.
Last Edit:1 year 5 months ago by Cobber
Last edit: 1 year 5 months ago by Cobber.
  • Hogweed
Replied by Hogweed on topic Guess what - HGF
Posted 1 year 5 months ago #210848
Thanks everybody. Yes just trying to track a specialist down here in NI is the problem - we did have an excellent guy who was a magician with all things MGR, but he lost interest a couple of years ago and just packed the whole thing in. Sadly he can't recommend anybody else either, so it may be a struggle. I have one lead to follow up - will post any updates here.
The guy is about 15 miles away - I'm assuming it wouldn't be a great plan to drive the car to him
by Hogweed
  • Hogweed
Posted 1 year 5 months ago #210852
Update - managed to get hold of him. He's done dozens of these in his long career (ex main MGR dealer mechanic here) and can do it in February hopefully. Will post updates...
Last Edit:1 year 5 months ago by Hogweed
Last edit: 1 year 5 months ago by Hogweed.
Replied by TA22GT on topic Guess what - HGF
Posted 1 year 5 months ago #210855
Good news! Fixed in time for a Spring outing.
Replied by Notanumber on topic Guess what - HGF
Posted 1 year 5 months ago #210860
Thats really good news
  • Hogweed
Posted 1 year 5 months ago #210926
So... my local guy is now showing signs of not wanting to do it - though he used to be a specialist, that's years ago now, and I think he's less keen than expected.
There is still a semi-local expert, but he's about 15 miles away. So the question is... I've only driven maybe 20 miles since I noticed the problem. Would it be very inadvisable to drive it slowly to him, with maybe an hour's break in the middle, or would this be seriously risking making things worse?
Ta
by Hogweed
Replied by R40MGF on topic Guess what - HGF
Posted 1 year 5 months ago #210928
Hi,
It maybe worth having a look at Rough Luck Racings web site.
I know that they used to get around quite a bit, UK wide and most of Europe.
Replied by generous_dad on topic Guess what - HGF
Posted 1 year 5 months ago #210929
Or Russell Walsh. He did mine in the middle of January, outside. Good man.
  • Hogweed
Posted 1 year 5 months ago #210934
Thanks for the recommendations - unfortunately, a phrase we in my part of the world get very familiar with is "excludes NI"
by Hogweed
Posted 1 year 5 months ago #210935
The ride of shame.......on the back of a tow truck!
Replied by D4KGP on topic Guess what - HGF
Posted 1 year 5 months ago #210936
Ta
When I acquired my F I drove it home about 15 miles topping it up with water every now and then with no big problem,  but my Son followed in his car with a tow rope just in case but it wasn't needed. When we got it home it was a split hose that was leaking, but all the same to that I did do the H/G,  its not that hard to do on an F!  Finding it far more of a job on the 2002 160 VVC. So my advice would be:  get it insured then get a friend to tow it gently to the person you have in mind to do the repair.  Good luck Glyn  (D4KGP)
Replied by Airportable on topic Guess what - HGF
Posted 1 year 5 months ago #210937
If that becomes a plan, do make sure that you affix the tow strop to a point where the front bumper is still with the car & in one piece, on arrival. Particularly if you have a front splitter! My advice would be to remove the bumper, there may be eyes on the subframe, these are for for tiedowns & not a near horizontal pull.
Time to create page: 8.065 seconds
