1998 Caterham Superlight R K Series VHPD Engine
1998 Caterham Superlight R K Series VHPD Engine was created by CATSLR
Posted 7 months 2 weeks ago #220657
I have a 1998 Caterham Superlight R fitted with the original K Series VHPD engine.
The car features a OBD2 interface (16 pin).
The engine is controlled via a MEMS 1.9 ECU.
I'm trying to find the appropriate diagnostic scanner for my car.
Can any members recommend or suggest an appropriate device ?
by CATSLR
Replied by Cobber on topic 1998 Caterham Superlight R K Series VHPD Engine
Posted 7 months 2 weeks ago #220660
You've come to the right place..................Although it is an OBD2 plug socket it is OBD1 for MEMS 1.9
A PScan diagnostic reader should work for you.
Replied by talkingcars on topic 1998 Caterham Superlight R K Series VHPD Engine
Posted 7 months 2 weeks ago #220666
Hi and welcome to the forum.
As Cobber says, the port is an OBD1 port and the www.pscan.uk is the diagnostic tool for the job. There are alternatives solutions but they are much more expensive and less user friendly.
James
Replied by CATSLR on topic 1998 Caterham Superlight R K Series VHPD Engine
Posted 7 months 2 weeks ago #220672
Many thanks Cobber
by CATSLR
Posted 7 months 2 weeks ago #220673
Many thanks James
by CATSLR
Replied by pscan.uk on topic 1998 Caterham Superlight R K Series VHPD Engine
Posted 7 months 2 weeks ago #220707
Send me a PM or an email.
I am confident that it will work.
Posted 7 months 6 days ago #220825
Today, 9th December, I received, via DHL my Pscan. Upon unpacking all seemed fine, there was no physical damage evident. However, closer inspection revealed a rattle when I gently shook the device, the serial port on the back of the device was loose, is this normal ? I have not yet tried the device on my car. I live in Perth, Western Australia and unless absolutely necessary I don't want the hassle and expense of having to return the device to the UK. Any comments or advice would be welcomed.
by CATSLR
Replied by Airportable on topic 1998 Caterham Superlight R K Series VHPD Engine
Posted 7 months 6 days ago #220830
The PCB was a loose fit in mine when it landed. There are tolerances in any low volume production items & a mil’ out in a board or box can cause this. If it works, as mine does, don’t worry.
I’m making a special enclosure for a circuit, it’s number three of a design. I started making it before the board arrived, which came earlier & it won’t fit; the board has grown. I’ll have to remake a couple of bits , which is a bugger. Three devices, two of which are exactly the same & one, which is functionally identical but larger.
Posted 7 months 6 days ago #220832
Hi Airportable
Thank you for your response, I'm reassured.
by CATSLR
Posted 6 months 3 weeks ago #221120
A bit of a rattle is normal.
I make these in batches of one hundred at a time.
This makes it much harder to achieve the same tolerances as something like an iphone.
The design decision I made was that people would care more about how well it works for a reasonable price than that it feels nice like an mass produced item.
The cases are made from machined plastic sheet that's folded into shape, they aren't molded like products that are produced in the hundreds of thousands.
Time to create page: 1.871 seconds
