P1522 variable intake solenoid #2 circuit malfunction
P1522 variable intake solenoid #2 circuit malfunction was created by Follyjunk
Posted 7 years 3 months ago #190173Next week MOT (APK), i checked the ECU for faults (pscan) and found some faults. I only drove the car for maybe 1 km and not yet revved more then maybe 3000/3500 rpm.
All of them are not interesting because of the conversion, except fault P1522 has my interest. I have already tested the VVC control by driving the both solenoids directly with 12V. I removed the camshaft cover, marked the position of the shaft and checked increasing and decreasing, that works. I measured the resistance of the coils, both around 8 ohm.
Q1. Does anyone know what is the trigger for this fault ?
Q2. Which values are interesting to log with the pscan to analyse the cause ?
Replied by talkingcars on topic P1522 variable intake solenoid #2 circuit malfunction
Posted 7 years 3 months ago #190175Personally I'd clear the fault and go for a decent drive to make use of the VVC and then see if the fault reappears.
Also check the 2 plugs on the VVC unit are the correct way around, it is possible to swap them and lose VVC.
James
Replied by Follyjunk on topic P1522 variable intake solenoid #2 circuit malfunction
Posted 7 years 2 months ago #190267When i reset the fault when the car is already idling then go for a spin and read the the errors it is not there.
When i switch off -> on again without starting the fault appears.
WIll try to measure whether coil 1&2 have 12v during ignition on.. maybe coil 1 has supply and 2 does not until started..
I made a log measured(orange0 cam v requested(blue) cam position, all looks fine
- trevorgetty
- Apprentice MGer
Replied by trevorgetty on topic P1522 variable intake solenoid #2 circuit malfunction
Posted 6 years 3 weeks ago #193573I have just done a 143VVC conversion to 160VVC MEMS3 so similar conversion on my MGF.
I have a error codes like your to do with A/C but as I dont have a/c I dont care.
The main one is P1522 which is the VVC solenoid 2 as you have said..
I have yet to drive the car so it could be the solenoid is out of position during the belt change - I am not sure.
Please let me know if this resolved itself with a good drive?
Thanks trevor.
- trevorgetty
- Apprentice MGer
Posted 6 years 3 weeks ago #193601So p1522 remains.
ive checked my vvc leads continuity and pin out is corect.
Doesnt change regardless of which lead is removed from vvc mech though which is strange.
Ive put an oscilloscope on the ecu driver pins at the solenoid side both show a falling edge from 12v to 0v for a brief period on ignition on just to test the circuit so ecu looks fine.
I cant see anything else currently.
I still haven't started the car so i will do this next and reset to see if it goes away...
Replied by David Aiketgate on topic P1522 variable intake solenoid #2 circuit malfunction
Posted 6 years 3 weeks ago #193605David
- trevorgetty
- Apprentice MGer
Posted 6 years 3 weeks ago #193608I am going to go start the car to see if that helps, but keep the ideas coming?
Posted 6 years 3 weeks ago #193617trevorgetty wrote: I am going to go start the car to see if that helps,......
do it, do it, do it.....
Replied by Torda on topic P1522 variable intake solenoid #2 circuit malfunction
Posted 1 year 10 months ago #208263I have the same problem. Some solutions?
