EMS code
EMS code was created by Lezbrouf
Posted 7 years 2 months ago #190302
Hello everyone,
I have several ECU and LUCAS 5as not paired because they come from different cars.
My goal: to synchronize each ECU with a LUCAS 5as.
Problem: My Pscan does not read EMS code from the ECU but read the EMS code from lucas 5as.
Another problem (so that it is more funny): I erased all the codes EMS from lucas 5AS :slapme:
How can I read the EMS from ECU?
Replied by pscan.uk on topic EMS code
Posted 7 years 2 months ago #190304
The only way to know an engine ECU EMS code is to connect it to a 5AS that you know the EMS for, or set it in the 5AS and then use the learn feature.
Once an engine ECU has learnt the EMS from a 5AS then you will know what it is.
There isn't a way to read the EMS code directly from an Engine ECU.
Last Edit:7 years 2 months ago by pscan.uk
Last edit: 7 years 2 months ago by pscan.uk.
The following user(s) said Thank You: Lezbrouf
Replied by talkingcars on topic EMS code
Posted 7 years 2 months ago #190306
Hi and welcome to the forum.
If you power up the 5AS you can connect a fob to it, you can then match the 5AS to the engine ECU.
I have one fob that is matched to all my 5AS cars (currently 3 cars).
James
Replied by Lezbrouf on topic EMS code
Posted 7 years 2 months ago #190312
Hello,
Thanks very much!!!
Si j'ai bien compris:
Je prends un ECU from a car and 5AS from an other car without EMS, j'écris le code EMS dans le 5AS puis mode aprentissage pour les synchroniser. C'est exact?
Question: Le ECU aprend le code EMS from 5AS?
Posted 7 years 2 months ago #190313
If I understood correctly:
I take an ECU from EMS, I write the EMS code in the 5AS and learning mode to synchronize them. That's right?
Question: Does the ECU know the EMS code from 5AS?
Sorry, I'm french :)
Posted 7 years 2 months ago #190315
Yes. If you want a specific EMS code (for example if you have multiple identical cars you can set them all the same and then you can swap ECUs between the cars more easily).
1. Log into 5AS and set the EMS that you want.
2. Log into Engine ECU and select "learn EMS".
Posted 7 years 2 months ago #190318
WOW!!! super!
Thanks you very very much! you are the Boss B)
I'll try it and I'll tell you if it's ok ;)
It would deserve a little tutorial :lol:
It's really great to be dealing with competent and passionate people.
I doubt that there is such support for other car brands.
Without wanting to pollute this subject: Will it be possible with the Pscan in the near future to have the same options from MEMS 1.9 to MEMS 2J (Tuning of open loop enrichment, ignition timing, ...)?
Thanks again for all!!!
Posted 7 years 2 months ago #190320
Lezbrouf wrote: Without wanting to pollute this subject: Will it be possible with the Pscan in the near future to have the same options from MEMS 1.9 to MEMS 2J (Tuning of open loop enrichment, ignition timing, ...)?
Unfortunately MEMS 1.9 and MEMS 2.0 are not modifiable.
Posted 7 years 2 months ago #190322
I wanted to talk about that
Posted 7 years 1 month ago #190582
Hello everyone!
A thousand excuses to come back so late but here is the next thing.
EVERYTHING IS WORKING and OK!!!!
And here is also a small explanation in picture (FR and EN).
It will avoid being nights in his garage :)
This browser does not support PDFs. Please download the PDF to view it: Download PDF
Posted 6 years 10 months ago #191220
Hello dear,
today I test to synchronize diesel ECU (EDC1.3.1) with a new 5as but there isnt option "immobiliser". How I do? Is it possible to synchronize?
Time to create page: 4.708 seconds
