cant go into ABS on a Defender
Hi, Please can you help me get into the ABS on a Defender 2005. I can go into the engine ECU, but not the ABS, ECU
Thanks
Thanks
by purjohn
For a Defender you should be using Wabco D. We have tested this on a 2003.
by pscan.uk
Thank you, When,t into it to day NO problem, no fault codes found,
The Frence MOT tester is saying that the ABS light should go out when it is started and not driven on the road, before the light goes out which it is doing. Im going to phone a land rover garage in the uk tomorrow
Thanks again for your help
by purjohn
Check out this thread https://www.the-t-bar.com/forum/pscan-uk-diagnostic-tool-forum/96526-logging-data-to-a-file
Rob was having intermittent problems with ABS. He used the logging feature to log all four wheel speed sensors and then he went for a drive.
Then he plotted the live data in excel and you can see that one sensor behaves differently to the other three.
by pscan.uk
Time to create page: 1.347 seconds
