Oxygen sensor not okay
  • jonaf
  • Apprentice MGer
  • Apprentice MGer
Oxygen sensor not okay was created by jonaf
Posted 6 years 10 months ago #191338
What does "Oxygen sensor status not okay" mean? The sensor is brand new and the engine is running extremely rich. Sensor voltage is static. No fault codes present.
Last Edit:6 years 10 months ago by jonaf
Last edit: 6 years 10 months ago by jonaf.
Replied by pscan.uk on topic Oxygen sensor not okay
Posted 6 years 10 months ago #191339
Which ECU is this?
  • jonaf
  • Apprentice MGer
  • Apprentice MGer
Replied by jonaf on topic Oxygen sensor not okay
Posted 6 years 10 months ago #191340
MGF '97 1.8 Mpi
by jonaf
Posted 6 years 10 months ago #191341
So MEMS2J ?
  • jonaf
  • Apprentice MGer
  • Apprentice MGer
Posted 6 years 10 months ago #191342
MEMS 1.9
by jonaf
Replied by talkingcars on topic Oxygen sensor not okay
Posted 6 years 10 months ago #191372
pscan.uk wrote: So MEMS2J ?
The VVC uses MEMS 2J, the 1.8i is MEMS 1.9
Posted 6 years 10 months ago #191373
Jonaf - what brand of sensor did you use?
Was it universal or did it have the correct plug.
What are the readings for the probe heater circuit?
  • jonaf
  • Apprentice MGer
  • Apprentice MGer
Posted 6 years 10 months ago #191380
The sensor i OE MG Rover. Regarding the reading for the probe heater circuit I do not know where to find this. Maybe this is the "Oxygen sensor not okay"?
Posted 6 years 10 months ago #191390
Mine is a VVC so MEMS 2.0 so slightly different but I'm sure the heater circuit had it's own listing.
Replied by Hyse on topic Oxygen sensor not okay
Posted 6 years 7 months ago #192039
Hello,
i have exactly the same problem.
The Oxygen Sensor ist brand new and original ( Bosch )
The wiring is ok too.
Fuses are ok.
Any tips?
Greetings from Germany
Hyse
MGF, MPI, Mems 1.9
Last Edit:6 years 7 months ago by Hyse
Last edit: 6 years 7 months ago by Hyse.
Replied by Fjack on topic Oxygen sensor not okay
Posted 5 years 6 months ago #194857
Hi all,
I’m new here, and was just trying the Pscan after replacing the O2 sensor for a new one I got from Rimmer Bros for my 98 1.8i MGf with the ECU MEMS 1.9.
After failing the Mot on the gas emissions control, I checked and there were no fault codes but had the the exact same reading with de voltage fixed at 0,44V and the message “Oxygen sensor not Ok” so I decided to replace it.
Unfortunately the reading remains the same, :(
Did any one of you guys got any clue on why this is happening and how to solve this issue?
Cheers
by Fjack
Replied by David Aiketgate on topic Oxygen sensor not okay
Posted 5 years 6 months ago #194861
:welcome2:
Sometimes the wiring is damaged by heat from the exhaust. You need to check the wiring and the plug.
Last Edit:5 years 6 months ago by David Aiketgate
Last edit: 5 years 6 months ago by David Aiketgate.
Time to create page: 0.686 seconds
