Pektron autolock disable
Pektron autolock disable was created by roperman
Posted 6 years 3 months ago #192893
Hi,
Just wondering if pscan can remove the autolock on zr/zs pektron cars that occurs when the vehicle is moving?
Thanks,
Danny
Replied by pscan.uk on topic Pektron autolock disable
Posted 6 years 3 months ago #192942
We will look into it.
Replied by PXMGZR on topic Pektron autolock disable
Posted 4 years 2 months ago #198947
Hi, I am thinking about a pscan so I can program a couple of extra fobs and get my own EKA (MGZR 2005). I Would also like to disable the auto lock as my internal unlock button doesn’t work and I can not find the fault. So to unlock, I have to switch the ignition off which is a pain.
So can you let me know if pscan can disable the autolock central locking. That probably makes my mind up to buy one rather than have than just have the fobs done by somebody else.
Many Thanks
by PXMGZR
Replied by sworkscooper on topic Pektron autolock disable
Posted 4 years 2 months ago #198953
Hi . If I can just jump in here . For Pscan to program fobs , you will need to have the bar code that came with the fob . If however you intend to buy a pair of new fobs , then the bar code will come with them . Don't buy a second hand fob without the code as Pscan will not help . If you send your Pectron unit to Technozen ( Paul Brown ) I believe he can work his magic on fobs without the code but you would be best contacting him first to ask .
John
The following user(s) said Thank You: PXMGZR
Posted 4 years 2 months ago #198954
pscan can't disable the autolock feature at this time
Replied by Roverlike on topic Pektron autolock disable
Posted 4 years 2 months ago #198955
John
Paul cannot code any second hand Pektron fob to any Pektron SCU. What he can do is copy memory of existing SCU to another SCU and existing fobs will work on new SCU unit.
The following user(s) said Thank You: sworkscooper, PXMGZR
Replied by Cobber on topic Pektron autolock disable
Posted 4 years 2 months ago #198958
This Pektron security problem looks a total pain in the arse, I think it's time to look at some ways of bypassing this electronic rubbish as it would appear to be lingering long past it useby date. I recently by passed Ford's similar "Smartlock"system on my ute. I my case it was as simple as by passing two wires.
I know that there will be cries of "what about the insurance companies?" If you don't tell 'em how would they know? They won't be looking that close.If they wanna stiff you outta a payout they'll just do it anyway using fine print and legalese, just like they've always dome to shirk their financial responsibility!
They're not going to unpick the wiring loom
Replied by Raccoon on topic Pektron autolock disable
Posted 4 years 2 months ago #198959
by Raccoon
Replied by minimax on topic Pektron autolock disable
Posted 4 years 2 months ago #198961
In theory, the pektron system could be replaced with the earlier model' s parts but in practice, there are a lot of wiring loom changes needed. Somewhere there will be a digital signal to the ecu that tells it to start the engine. Copying that might be possible using a logic analyser, as long as it always sends the same instruction. I do not expect the code hopping to occur here but until I get my mitts on aTF to hack into, I won't know if it can be done.
by minimax
Posted 4 years 2 months ago #198970
Ok thanks. It seems I have got it working now anyhow. After stripping it all down testing all the wring and putting it all back together for second time. Maybe it was just a high resistance connection issue or some gremlin waiting to return.
by PXMGZR
Posted 4 years 2 months ago #198980
The code that the Pektron sends to the engine ECU is in the same format as that sent by the older 5AS system, and it can be faked with a Simtek unit.
There is a video about that here
However the Pektron does also do other things to immobilise the car, like controlling the fuel pump I think.
Also many of the other systems of the car are controlled by the Pektron.
To be honest they aren't that bad, and at least can be cheaply repaired by Paul if they do go wrong. It could honestly be a lot worse.
I probably have the capabilities to remove it from my Rover 25 but I think it's just easier to leave it as it is.
Time to create page: 2.238 seconds
