Interface Failed: Interface not powered
- Captain Slow
- Novice MGer
Interface Failed: Interface not powered was created by Captain Slow
Posted 3 years 9 months ago #195094The led on the end of th eunit does not iluminate when connected to the laptop. Should it be lit when not connected to the car?
Help!
Replied by pscan.uk on topic Interface Failed: Interface not powered
Posted 3 years 9 months ago #195097I think that I need to change the warning message, this is the most common query from new customers.
Replied by Brummy on topic Interface Failed: Interface not powered
Posted 3 years 8 months ago #195182Please Log in or Create an account to join the conversation.
Replied by talkingcars on topic Interface Failed: Interface not powered
Posted 3 years 8 months ago #195183Do you have a pscan unit?
This is needed to connect between the MG and the pscan software.
James
Posted 3 years 8 months ago #195185Please Log in or Create an account to join the conversation.
Posted 3 years 8 months ago #195190Please Log in or Create an account to join the conversation.
Replied by Jon-Mini on topic Interface Failed: Interface not powered
Posted 3 years 8 months ago #195192Its a very exclusive Club
All members buy the very useful PScan unit that does a great job on our engines..
You're welcome to join the happy band of members..
Posted 3 years 8 months ago #195194I have no idea what a Super Scan OBD2 connector is, but at a guess it will be an ELM237 based or ELM237 clone based device.Brummy wrote: Oh! So even thouIgh I have already got an ECU Super Scan ODB2 connector, thats no use?
The list of protocols that the ELM327 chip supports is not wide enough for MGs and Rovers.
The ELM chip is basically designed to cover OBD2 and EOBD standards based protocols, but very little in the MG and Rover era cars is standards compliant.
In order to solve this we designed our own interface.
We made is as cheap as we possibly could, but it's not free.
Replied by David Aiketgate on topic Interface Failed: Interface not powered
Posted 3 years 8 months ago #195195If you have a mems3 car,i.e. coilpacks atop the cylinders and two lambda/o2 sensors then you can use the Torque App on your phone to connect to your elm27 obd2 device. This will give you basic info, but nowhere near as comprehensive as the pscan unit.
Elm27 units cannot connect to earlier MGs.
