Can I drive MG tf with Cooper grease in coolant bottle?
Can I drive MG tf with Cooper grease in coolant bottle? was created by Siya
Posted 2 years 9 months ago #198316
can I drive my MG tf with Cooper grease in coolant bottle? What causes Cooper grease in the coolant? Is it safe to drive it?
by Siya
Replied by David Aiketgate on topic Can I drive MG tf with Cooper grease in coolant bottle?
Posted 2 years 9 months ago #198318
Is it perhaps, that someone has added radweld (or similar) to the coolant in an attempt to stop a leak? That can look like copper particles. If so you can drive it, but you need to find the leak.
Replied by talkingcars on topic Can I drive MG tf with Cooper grease in coolant bottle?
Posted 2 years 9 months ago #198324
Hi and welcome to the forum
I would be worried that if it was copper slip that it would block a water way.
As David suggests it could be radweld which is not the best in the K series but not as bad as copper slip.
James
James
by talkingcars
Replied by Cobber on topic Can I drive MG tf with Cooper grease in coolant bottle?
Posted 2 years 9 months ago #198326
Copper and aluminum are not compatible, so if it is copper it will corrode your alloy engine away
Time to create page: 0.495 seconds
