Interrogating Lucas 5AS
Replied by mowog73 on topic Interrogating Lucas 5AS
Posted 1 year 10 months ago #200907
Note that you can do remapping of engine ecu at people like KMaps or SAWS tuning. In that case you will have engine ecu with erased need for pairing to alarm ecu. Then you can disable alarm ecu by pulling out the fuse of Lucas system and alarm system will be disabled - but also central locking will be disabled as well, so no use of fob will be present. You will not have passive immobilisation any more as well.
How your insurance will react in this case is up to you and your insurance.
Is this true for just MEMS3 or MEMS1.9 as well, that the alarm system can be disabled by pulling the fuse of the Lucas system? I would like to disable the passive immobilisation system in my 1995 F.
[size=10pt]Mark[/size]
95 MGF
by mowog73
Replied by Roverlike on topic Interrogating Lucas 5AS
Posted 1 year 10 months ago #200908
As I said in the begining of that post: you need to have engine ECU which have removed need for pairing with alarm ECU. If you have this removed, you do not have passive immobilization any more and in that case you do not need to disable alarm ECU.
It can be done on MEMS 1.9 but it needs to be done by removing chip from ECU and reprogramming it and put it back.
Replied by pscan.uk on topic Interrogating Lucas 5AS
Posted 1 year 10 months ago #200910
you can also do it with a Simtek as shown in this video
Replied by Delbourt on topic Interrogating Lucas 5AS
Posted 1 year 10 months ago #200912
Thank you for pointing me in that direction.
Grief, how many MBs?
On our internet speed here it would take all day. Somehow I think I’ll have to travel hopefully and rely on some interpretation of the later diagrams.
It would be nice though.
Posted 1 year 10 months ago #200916
I thought I had replied to this, but perhaps not. Thank you for pointing me to the other area.
The second download section has downloads of many megabytes that would take me all day to download here at home.
There must be another source or way to get a wiring diagram for a 2002/2003 TF.
I suspect I’ll have to live with the later version.
Replied by BruceTF135 on topic Interrogating Lucas 5AS
Posted 1 year 10 months ago #200917
Whereabouts are you? It shouldn't take long to download the RAVE B archive over broadband. It took just over 2 minutes for me although my broadband is quite fast (35Mbps). If you are in the UK, I don't mind burning it onto a CD and posting it to you for a pint. Send me a private message.
Posted 1 year 10 months ago #200919
Ok, downloaded using a different PC on a quiet day for the area. However, could not open a bloomin thing kept getting an error message "something went wrong".
I guess I'll live in ignorance. All I wanted was the wiring diagram. I have a copy of the WS manual although that is not the best presentation of how to do things in my view as it keeps referring to another section.
But thanks for the offer of help. I'll see if I can get a copy from the web somehow.
Posted 1 year 10 months ago #200920
No, having downloaded it and extracted the archive into its own directory, it doesn't work for me either.
I'm using Windows 10 Professional 64bit.
I try to run tdata.exe and all that happens is I get a quick flash of an ancient Acrobat Reader screen pop-up and that's it. I cannot open any of the .pdf files either using Acrobat Reader version 2022.003.20282 ¦64-bit.
The README file mentions an error MULTIUSER SECURITY HANDLER EXPIRED means you should reset your clock but I don't see this error and I'm not sure that you can change the clock on a PC these days anyway.
Posted 1 year 10 months ago #200921
Have you tried to apply any of two proposed methods here: https://www.the-t-bar.com/forum/54-how-tos/98235-rave-disc in order to make it work on Windows 10 or 11?
I also did not have any problems changing time and date on PC on which I am admin.
Last Edit:1 year 10 months ago by Roverlike
Last edit: 1 year 10 months ago by Roverlike.
Posted 1 year 10 months ago #200922
Yes, deleting those 2 folders in the Acrobat4 folder sorted the problem out. When I started up by running TData.exe, I was asked to accept the Adobe conditions and then it opened up with the splash screen
Then everything seems to work well.
Thank you for the solution. Would it be possible to include this in the README file in the download zip file?
@Delbourt, here you go :-)
Posted 1 year 10 months ago #200923
BTW, You are also right about the date. Mine was set to maintain the time and date automatically. There is an option to go manual and change the date.
However, I'd prefer not to do that on my office PC as I'm not sure what the implications might be for other important stuff I am using/doing.
Replied by kiwikk on topic Interrogating Lucas 5AS
Posted 10 months 2 weeks ago #205311
pscan is reverse engineered from the factory MG Rover diagnostic tool (T4). I can only implement features in pscan that MG Rover put into the T4.
That's so cool Pscan!. Reverse Engineering computer firmware to help monitor and control our practical engineering projects. Real IT!
Thanks
PS. I understand T4 can disable the 5AS system. ;)
by kiwikk
Time to create page: 0.599 seconds
