SRS
  • PipL
  • Journeyman MGer
  • Journeyman MGer
SRS was created by PipL
Posted 3 years 2 months ago #202246
Hi all.
My SRS light is permanently on while the ignition is on.
I have checked the plugs under the seats and cleaned and all fine.
The light on the dash is sometimes dim, but sometimes bright so i thought bad earth and cant find one, the only thing I did before it came on was add a wire so that I can wipe/wash at the same time with a 3 sweep cycle.
I have plugged my Pscan in, no general faults found, went into airbags, selected RC5, it goes through the normal initiation then goes back to the main menu, I have checked all the other airbag links and nothing.
My car is a MK1 MGF VVC 1998.
This is doing my nut.
Any help to reduce my drinking heavily to numb the pain will be received with lifetime gratitude
Regards
Pip.....
by PipL
Replied by exeterjeep on topic SRS
Posted 3 years 2 months ago #202247
some years ago had to replace the srs ecu on my ZS. Pscan would not connect to it... and I also noticed that when turning the ignition on, the SRS did not flash off and then back on to indicate that it had detected a fault. bought a new ecu arrived next day, problem solved.
The following user(s) said Thank You: PipL
Replied by Airportable on topic SRS
Posted 3 years 2 months ago #202252
Have you removed the wash/wipe link & is it still problematic, is there a passenger air bag, have you been working near the airbag ecu & moved the connector in any way. I’m on holiday at the moment plus I’ve no idea where you live, but if you’re close to me when I’m home I’ll let you have a couple or three ecu’s to experiment with (don’t ask why I’ve ended up with a surfeit of ecu’s) not expecting to get them back. Oh & there’s a big fat earth down there in the darkness, always good for another quarter turn.
  • PipL
  • Journeyman MGer
  • Journeyman MGer
Replied by PipL on topic SRS
Posted 3 years 2 months ago #202253
Hi, no i haven't disconnected the wire, its soldered in but i guess i will have to try.
I live in Solihull, Birmingham, I havent been anywhere near the ecu..
by PipL
Posted 3 years 2 months ago #202257
Get that wire cut, don't take it out, if you like the addition & it's not that, you can remake the joint without having to bother the soldering iron again. Is the mod a proprotorial job or have you worked back from the drawings. I did something similar many years ago & it's written up on here somewhere, but I've not had any bother with any other service.
I live in Lancashire so it's a bit of a stretch from Solihull, even if the ecu's are gratis..
  • PipL
  • Journeyman MGer
  • Journeyman MGer
Posted 3 years 2 months ago #202258
I shall cut it tomorrow and see, its a mod that i have seen in a manual plus everyone has told me about.
yeah it is a bit of a jaunt and I wouldn't take advantage of a gratis gesture, i would have got it back to you. i will look tomorrow and get back to you.....cheers
by PipL
Replied by pscan.uk on topic SRS
Posted 3 years 2 months ago #202264
selected RC5, it goes through the normal initiation then goes back to the main menu,.
I think that you are saying the pscan cannot connect to the SRS ECU at all.
Make sure that there is a power going to the SRS ECU, as well as a good earth.
If the SRS isn't receiving power then pscan won't connect to it.
Time to create page: 0.437 seconds
