Crank sensor signal
I have this fault code. Can anyone shed a little light? Mems 1.9. Car starts and runs fine so sensor must be working.
“crank sync (not normally a fault)” also appears.
I’ve searched this forum but can’t see any answers.
Thanks in advance.
Thanks in advance.
Last Edit:1 week 1 day ago
by kernow
Last edit: 1 week 1 day ago by kernow.
Try clearing the fault......if it comes back you have a problem, if it stays cleared you don't!
Already did that but it reappears. However I have no driving issues.
by kernow
Puzzled am I.
The error codes included “coolant temp sensor”
As this is easier to replace than the crank position sensor, I changed it.
Both crank sensor error messages disappeared, along. with the coolant sensor message.
How can there be any connection?
I have one crank position sensor now going cheap….
by kernow
Sounds like the crank sensor fault was a glitch in the code reader. A crank sensor fault would probably stop the car running...
The following user(s) said Thank You: kernow
Thanks. I did clear fault codes 2 or three times.
I’m new to pscan but I hope glitches are not part of the package.
by kernow
Time to create page: 0.457 seconds
