Hi! I just bought an MG TF from 2003 and need some advice
Replied by Airportable on topic Hi! I just bought an MG TF from 2003 and need some advice
Posted 1 week 3 hours ago #208801
I do like the expression “mechanical sympathy” as used by our friend TA22GT, it might be an interesting addition to the riggers of the driving test.
Mind you when you observe the lack of ability & “roadmanship” of many drivers these days it makes you wander whether there are any riggers at all!
It wasn’t too long ago that the sight of a car with the bonnet raised at the roadside was unusual, now with the lack of Mech’Symp you might see several even on a short journey.
Just keep pumping fuel in & well just keep pumping fuel in. A Service, what’s that?
A fresh car is another language you have to learn & the more you study the quicker you learn. You also need the text book, crib notes & folk around you who will teach you polite parlance & the slang.
In T-Bar you have all that & Cobber for free.
An assiduous learner is never a liability.
You might be starting with an existing tool kit & fair dos if not buy wisely & buy quality but unless you are going to use them day in & out don’t end up a Snap-On sucker.
You can get some eBay bargains, I’ve had Britool spanner as new for a song, 8,10,13,15,17 & 19mm ring/open ended 3/8” sockets & good ratchet, extension bar.
Other hand tools are common sense. A test meter, a battery/buzzer tester for continuity.
And if you don’t have one fitted, a good low coolant warning system (see Bruce).
by Airportable
The following user(s) said Thank You: SynchroMesh
- SynchroMesh
- Novice MGer
Replied by SynchroMesh on topic Hi! I just bought an MG TF from 2003 and need some advice
Posted 6 days 23 hours ago #208810
thank you very much, roughly how many Litres of oil and coolant is needed?
by SynchroMesh
- SynchroMesh
- Novice MGer
Posted 6 days 23 hours ago #208811
thank you very much for the advice, would you say the coolant warning system from MGOC spares is a good bet?
by SynchroMesh
Posted 6 days 22 hours ago #208812
It’s all there in the library, have a look there & download what you could find useful. I’m not being obtuse, I can’t remember & I’m not in the workshop.
Google it, it’s all there & Bruce’s low coolant monitor is used by loads of folk on here.
Come on Bruce, give us a wave!
I made my own as I’ve changed certain aspects of my coolant system.
by Airportable
Replied by TA22GT on topic Hi! I just bought an MG TF from 2003 and need some advice
Posted 6 days 22 hours ago #208813thank you very much, roughly how many Litres of oil and coolant is needed?
I just changed my oil and filter. It took about 4.5 ltrs.
Mine had been changed about 1000 miles before I got it with cheap oil so I did it again so that I know what is in it and when I put it in!
Haven't touched the cooling system yet apart from checking the level.
Replied by Notanumber on topic Hi! I just bought an MG TF from 2003 and need some advice
Posted 6 days 22 hours ago #208814
+1 for the low coolant alarms that our forum colleague Bruce Cotsell makes. Look for "MGF / MG TF - LOW COOLANT ALARM KIT - No Drilling Required - THE ORIGINAL! " on Ebay from seller Bcotsell.
They are one of the more cost effective low coolant alarms, it utilises your existing coolant bottle,and is easy to fit. Ive done 2 of them.
If Bruce spots this thread on the forum he may offer a discount for ordering directly.
It's worth bookmarking Mgfntfbitz site. Beside whats on their website they have a lot of good 2nd hand parts so it's worth dropping them an email to check when you need something. Excellent to deal with and its rare for me to go anywhere else..
You havent said whereabouts you are on the planet ?
Last Edit:6 days 22 hours ago
by Notanumber
Last edit: 6 days 22 hours ago by Notanumber.
- SynchroMesh
- Novice MGer
Posted 6 days 17 hours ago #208825
Im in London. I made the post very late at night. thanks for the recommendation this will save me a huge amount of money
by SynchroMesh
Posted 3 days 19 hours ago #208873
I just found this on YT. I'm not affiliated in any way but it will give you some insight in to a coolant alarm system.
Coolant Alarm.
Coolant Alarm.
Replied by MGB281 on topic Hi! I just bought an MG TF from 2003 and need some advice
Posted 2 days 19 hours ago #208874
There numerous ways to a low coolant warning alarm, this is what I used for a replacement expansion tank, they are better made than the MG one and are fitted with two prongs for sensing the coolant level, some vendors include the plug and a length of wire as this one does.
VW Volkswagen Polo 6R Coolant Reservoir Expansion Tank Fluid Bottle 6Q0121407B
I used the LOW water level version of this HIGH level alarm;
The seller will list one if you ask, because I have lost all of my high frequency hearing a buzzer is of no use to me but they do make one with a buzzer. Installation is simple, after mounting the tank with a short strip of metal for a bracket, you then connect the two white wire (they need to be extended to reach) to the expansion tank plug, then a source of power (I got mine from the USB charger that replaced the cigarette lighter) and fit the warning light. I placed the light in one of the switch blanks in front of the gearlever, when the LED flashes in alternating colours you will certainly see it. I got the idea from someone on the MGF Register
by MGB281
