Modifying the 48mm Throttle Body
Modifying the 48mm Throttle Body was created by PQD44
Posted 15 years 1 month ago #24624
The Problem?
In order to help the engine breath and increase air flow to improve torque and bhp it has been shown that it is advantageous to replace the standard 48mm throttle body with a 52mm one as fitted to Trophy 160.
The pre 2001 MGF were fitted with an SU plastic throttle body which has had a reputation for sticking due to a distorted body when hot generally caused by over tightening of a jubilee clip on the air filter side.
Later model used a Dellorto alloy throttle body.
52mm throttle bodies are expensive, ranging second hand ~ £70 - £100 and new around £140+. :(
How do I know which one is fitted to my car? Have a look between the air filter and the engine, the one in this photo is an alloy Dellorto throttle body. To the left is the large pipe leading to my K&N 57i filter, this is where you would normally find the standard air filter
If the throttle body is black plastic it is the SU 48mm. If it is alloy then on the upper edge you will find a code engraved on it with one of two codes
TV1 indicates a 48mm and TV5 indicates a 52mm throttle body.
More information on this subject can be found Here
Tools needed:
8mm socket on an extension, 8mm spanner, screw drivers, file, emery paper, solder, ceramic tile or other non metallic heat resistant flat surface
The Fix
You can modify your 48mm throttle body free of charge and the work is quite easy to do and can be completed in less than one hour. The results are an improvement over the standard 48mm version and the modification to the 48mm Dellorto detailed here is a popular modification made by Lotus Elise owners.
The modification involves the removal of the wedge attachment and filling the fixing holes. This wedge is fixed to the butterfly in order to soften the throttle response, to make the engine response more subdued at low revs. This wedge does however greatly restrict the air flow.
Depending on which throttle body you have follow the appropriate insttructions
The how to for the SU plastic throttle body can be found Here .
This is an excellent thread with lots of additional information and so I feel there is little point repeating it in this thread.
Note:The modification of the plastic throttle body is shown with quite a bit of work on the actual body as well as the butterfly. It is up to you how much you want to modify the body, but the vast majority of the gains will be achieved by just modifying the butterfly
Dellorto Alloy Throttle Body
After opening the boot and removing the wire cover the modification of the Dellorto throttle body starts with the removal of the unit which is attached to the air filter by a jubilee clip and to the plenum by 4, 8mm bolts.
The two bolts nearest the rear of the car are quite simple to reach with a socket on an extension and wrench, however the other two I found needed to be loosened with a spanner. Once loosened they can then be unscrewed by hand.
All that remains to complete removal is to disconnect the two rubber hoses, the throttle sensor plug and the throttle cable, which is held by the end of it by a T piece which needs sliding out.
If you require a pictorial guide to this refer to this article
With the throttle body removed you can now remove the metal wedge
Next you need to unscrew the two screws holding the butterfly to the spindle
To release the butterfly rotate the spindle 90 degrees, the butterfly disc will now just slide out
The disc now needs to be prepared for soldering by cleaning in and around the mounting holes which are no longer needed.
I used a blow torch to heat the disc but you could hold the disc in pliers and heat it over a gas cooker. The disc needs to be hot enough so that solder will readily melt and so fill the holes.
To do this place the heated disc on a tile or other non metallic flat surface and then touch the inside of the holes with the solder allowing it to melt and fill the holes.
Once cooled the area around the filled holes may be sanded smooth.
The following user(s) said Thank You: gotenks1321, Leigh Ping, tui
Replied by PQD44 on topic Re:fitting the throttle body
Posted 15 years 1 month ago #24625
Re-assembly is now just a case of rotating the spindle, inserting the disc and fixing with the two screws. Your throttle body should now look like this
which is a vast improvement in air flow compared to what you started with or the SU plastic bodied throttle
Refitting the throttle body is simply the reverse of removal.
Just make sure you reconnect the throttle cable first then fix the four bolts and finally the two rubber hoses not forgetting the throttle position sensor plug like I did first time ;) wondering why the car was sitting at 1800 revs in idle.
After moving things around or replacing a throttle body you need recalibrate the throttle position sensor.
To do this follow this simple procedure;
1. With the engine off, insert the key and turn to position 2, all the instrument check lights on, without starting the engine.
2. Press and release the accelerator pedal 5 times, using all of the accelerator pedal travel.
This will let the ECU calibrate the throttle position.
3.Turn the ignition off, remove the key and wait for the ECU to power down saving the new settings. This normally requires about 20 secs.
4. Start the car in the normal way. The throttle should now be reset.
Go for a drive, but do remember to let the oil temp get up before revving over 3000 rpm, now enjoy the difference, more torque at the low end and a more responsive throttle. With my K&N 57i I could also hear a difference. :cheer:
Last edit: 15 years 1 month ago by PQD44. Reason: improve clarity
The following user(s) said Thank You: psymon, David Aiketgate, Leigh Ping, CliffH, TA22GT
Replied by David Aiketgate on topic Re: Modifying the 48mm Throttle Body
Posted 15 years 1 month ago #24627
An excellent modification, Paul! :thumbsup:
Something to add to the list! :yesnod:
You could have also knife-edged the leading edge of the butterfly, to increase air flow. :yesnod:
Replied by gotenks1321 on topic Re: Modifying the 48mm Throttle Body
Posted 15 years 1 month ago #24633
Looks like it should make a good bit of difference. Am I the only one who would be worried about the solder falling out though? :ohmy:
Posted 15 years 1 month ago #24636
gotenks1321 wrote: Looks like it should make a good bit of difference. Am I the only one who would be worried about the solder falling out though? :ohmy:
I thought about that, but the thread in the hole should keep it secure. :yesnod:
Posted 15 years 1 month ago #24637
Ah yes, of course. I was thinking he'd smoothed the hole for some reason when he's just cleaned it up :silly:
I'm going to have to go and look at my 52mm now whilst I've got the filter off to see if it's the same setup.
Last Edit:15 years 1 month ago by gotenks1321
Last edit: 15 years 1 month ago by gotenks1321.
Posted 15 years 1 month ago #24642
Tbh, I was surprised that there was a wedge on there, I don't think I've ever seen it before.:shrug:
Replied by PQD44 on topic Re: Modifying the 48mm Throttle Body
Posted 15 years 1 month ago #24657
The wedge was originally there to make the throttle response more subdued, making the car more drivable by anyone around the supermarket car parks (not late at night doing doughnuts :lol: ).
Regarding the solder.
I chamfered the holes on both sides and heated the disc until it was hot enough to melt the solder with ease. Thus the shape of the solder is a sort of I (capital I) in profile so it cannot fall out and as long as the area is clean and the disc hot enough you will get a permanent bond.
Regarding feathering the leading edge, yes you can do that but be careful not to damage the sealing edge otherwise when the throttle should be closed you could get air entering. I reckon the improvements gained by removing the wedge are very large compared to the small extra gain from feathering the edge.
The following user(s) said Thank You: Peterpiper, Leigh Ping
Replied by tikkathreebarrels on topic Re:fitting the throttle body
Posted 14 years 3 months ago #46581
So this is what I have to do, and all I have to do, if I replace my 48mm body with a 52mm body?
Replied by David Aiketgate on topic Re:fitting the throttle body
Posted 14 years 3 months ago #46582
:yesnod:
Replied by bryan young on topic Re:fitting the throttle body
Posted 14 years 3 months ago #46939
PAUL, my 1996 MGF has an alloy throttle body on it, which was replacing the plastic one. very, very difficult to read the codes printed on the top , tried rubbing it but made it worse, as far as i can see the code is TV6 unable to read the other numbers even with a high intensity light. I have a loupe, see if that works :slapme:
Posted 14 years 3 months ago #46949
If it looks like a 6 then it's probably a 5 and someone has done you a favour and replaced the original with a 52mm throttle body. The way to be sure is to just measure it.
The other numbers are not needed to identify the size.
Time to create page: 0.449 seconds
